2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
FORscan Houston area
Old 06-06-2018, 09:51 AM
Tex68w's Avatar
Tex68w
Tex68w is offline
Tex68w is starting off with a positive reputation.
I will be in Katy this weekend, anyone in the area that can do some quick FORscan work on my truck? Thanks!
Old 06-06-2018, 10:32 AM
CACRanger
CACRanger is offline
CACRanger is starting off with a positive reputation.
What all do you need done? I may be able to help you out.
Old 06-06-2018, 11:04 AM
Tex68w's Avatar
Tex68w
Tex68w is offline
Most importantly I'd like to change the tire size (37x12.50x20) so that it reflects the speed and MPG's correctly along with lowering the minimum PSI/TPMS (50psi) so that I don't get the low tire pressure warning.
I wouldn't mind doing the following as well:
* Remove double honk when exiting with key while truck is running
* Auto fold side mirrors with lock/power off
* Add DPF% gauge
* Increase signal flash to 5 like it does in tow mode
* Extend power point time out for outlets
* Bambi mode for lights, high beams on with fogs
* Heated/cooled seats and heated steering wheel icon on home screen
* Add number over gauges
Thanks!
Old 06-06-2018, 11:12 AM
CACRanger
* Add DPF% gauge
Thanks!
What does your schedule look like for the weekend?
I have done all the above to my truck with the exception of:
* Add DPF% gauge
Do you know what code you want to input for the 37" tall tires?
Thanks,
Chris
Old 06-06-2018, 11:15 AM
Tex68w's Avatar
Tex68w
Tex68w is offline
I am free Saturday morning and through into mid afternoon. I can easily meet you wherever you like during that time frame. I have no clue what codes to use for any of this stuff. I was supposed to get together with another guy a few months back for all of this but it never happened lol. Is there somewhere I can look for these codes?
Old 06-07-2018, 02:16 PM
brentadams646
brentadams646 is offline
brentadams646 is gaining momentum as a positive member of FTE.
I think the maximum tire size you can re-calibrate the system using FORscan is 35's. I'm also running 37's, and everything I've read regarding 37's or larger, says that you can technically make the changes in the system, but it will ultimately result in a CEL. If you want to properly re-calibrate for 37's or larger, you need to use either a Hypertech inline module that plugs in behind the dash. I believe you can also do this if you're deleted and running a tuner, but I may be wrong.
CACRanger, since you have experience with this: I'm running 42 psi up front and 32 psi in the rear, can you adjust the parameters that low with FORscan? If not, can the low tire warning light be turned off while still being able to see and monitor the tire pressures?
Old 03-05-2019, 03:05 PM
tylerleach62
tylerleach62 is offline
tylerleach62 is starting off with a positive reputation.
Removing double Honk on f-250
I was curious if you still are interested in doing a little quick Forscan work. I would like to remove the double Honk feature whenever I leave my truck running . Iím in the woodlands area but can meet you obviously .
[email protected]
Old 03-05-2019, 06:31 PM
WEHRING
WEHRING is online now
WEHRING is starting off with a positive reputation.
X2
CACRanger - x2 on help please. Willing to pay. Was looking today to see what I need to buy to change my truck. Does not make sense for a one time adjustment.
Please call 9seven9 997 3one12
justin
Old 03-05-2019, 06:37 PM
CACRanger
Sorry guys, I have been swamped lately with work and my daughter's softball.
Shoot me a PM and I'll send you guys my cell phone so that we can text and set something up.
Thanks,
Chris
Old 03-05-2019, 06:38 PM
CACRanger
Yes...if you turn off the low pressure warning light you can still see the pressures on the monitor.
Thanks,
Chris
Old 03-05-2019, 08:51 PM
Toledo
Toledo is online now
Toledo is gaining momentum as a positive member of FTE.
anyone out in manvel/pearland area? im considering buying the stuff for forscan but id like some help from a live person not just a video
Old 03-05-2019, 10:05 PM
tylerleach62
It wouldnít let me PM you for some reason. My email is [email protected] if you donít mind. Donít know what the deal is.
Old 03-05-2019, 11:30 PM
Joe T
Joe T is online now
Joe T is gaining momentum as a positive member of FTE.Joe T is gaining momentum as a positive member of FTE.
Subscribing. Need to install the changable ambient lights first though!
Old 06-24-2019, 01:09 PM
tonywilliams6653
tonywilliams6653 is offline
tonywilliams6653 is starting off with a positive reputation.
Forscan
Thanks,
Chris
Can you do forscan on a 2018 f250. I want to get a couple things changed on my truck. I live in Houston. Shoot me a email if possible [email protected]
Old 07-09-2019, 01:46 AM
TexGuy's Avatar
TexGuy
TexGuy is offline
TexGuy is starting off with a positive reputation.
FORScan help needed
Hello Guys,
My 2006 Ford Escape has a bad Door Lock Actuator and I need to find out which one it is in the GEM Module / data logger with FORScan. I've had to order a new OBD cable to reach the data logger and may need some help with how to do this with FORScan, if that does not work I'm in the 290 area of NW Houston, lol
TexGuy aka Edward
Quick Reply: FORscan Houston area
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
