Does anybody drive with their exhaust brake on all the time - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 06-06-2018, 07:53 AM
Bohen
Bohen is offline
Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.
Just curious my buddy drives with his on all the time and told me yesterday you should drive with it all the time it helps recirculate the exhaust fumes so that they don't go back out don't know whether he's feeding me a line of horse poo or not
Old 06-06-2018, 08:00 AM
Just Strokin
Just Strokin is offline
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
No. Only time I turn it on is when in mountains and towing 5th wheel. Then I turn it on and off as needed. I believe you can get a DTC of turbo over boost when used all the time.
Old 06-06-2018, 09:13 AM
fordmantpw's Avatar
fordmantpw
fordmantpw is offline
fordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to all
I use mine on occasion when driving empty. I like it hilly areas or in-town driving. I use it all the time while towing. Your buddy is yanking your chain, though.
Old 06-06-2018, 09:42 AM
nuctrooper
nuctrooper is offline
nuctrooper has a good reputation on FTE.nuctrooper has a good reputation on FTE.
It certainly does not recycle the exhaust, which still flows out the tailpipe.
speaking for the ‘17+ at least, there are no detrimental effects with running it all the time. Won’t over boost or cause problems. Only spot to watch it is on slippery roads, as it can cause a significant braking action on the rear wheels that traction control/abs can’t correct and may lead to a skid.
Old 06-06-2018, 12:30 PM
Just Strokin
I think if Ford had meant for the exhaust brake to be activated all the time, Ford would either, 1) not put a switch to turn it on or off, or 2) it would be like traction control, always active unless you turn it off.
JMHO and 2 cents
Old 06-06-2018, 03:09 PM
99150's Avatar
99150
99150 is online now
99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation
JMHO and 2 cents
JMHO......if Ford didnít want it to be on at least most of the time, they would have put the switch in a handier spot, like on the steering wheel, or someplace where one does not have to take their eyes off the road to find it!! It is only active when ones foot is off the go pedal and the cruise is not active
Old 06-06-2018, 04:51 PM
mebe2k's Avatar
mebe2k
mebe2k is offline
mebe2k is gaining momentum as a positive member of FTE.
Must be a pretty weak exhaust brake...if I leave the jakes turned on in the peterbilt semi tractor I drive with no trailer hooked up the jakes darn near lock the rear wheels up..
Old 06-06-2018, 05:25 PM
99150's Avatar
99150
99150 is online now
it in no way even resembles a real Jacobs Engine Brake!!!! Whole different principle, but.........if one uses it like a Jake and downshifts, keeping the RPMís up it is still quite effective.
Old 06-06-2018, 05:44 PM
Just Strokin
JMHO Ford wanted you to know you turned it on by having to reach over and press the button. there was no brake on the 11-14 like on the 15=16 when they changed turbos.
Old 06-06-2018, 06:48 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to behold
No "Jake" brakes in our trucks in the early 70's!! Guess they didn't want us making excessive noise in the middle of the night! We did have compression release handles and front wheel braking limiter's. Never did find out what that second shift handle on the floor did!!!
Old 06-06-2018, 11:07 PM
99150's Avatar
99150
99150 is online now
and just FYI, mine is on just about 100% of the time, going on three years now, no issues so far.
Old 06-07-2018, 11:01 PM
pacnorwest
pacnorwest is offline
pacnorwest is starting off with a positive reputation.
I do a lot of coasting around town - the exhaust brake would ruin mileage. So no, I only use it when needed on down hill runs that would otherwise require brakes.
Old 06-09-2018, 02:16 PM
Joe/GA
Joe/GA is offline
Joe/GA has a good reputation on FTE.Joe/GA has a good reputation on FTE.Joe/GA has a good reputation on FTE.
I use mine a lot when towing because it help to slow down without using brakes. I did get a DTC and reduced power because of it. My dealer did some sort of flash and no more troubles.
Old 06-10-2018, 12:42 PM
Overkill2's Avatar
Overkill2
Overkill2 is offline
Overkill2 is gaining momentum as a positive member of FTE.
I don't tow yet but I use it only on a steep downhill road coming home so I don't have to ride the brakes.
Old 06-11-2018, 09:44 AM
Superdave71
Superdave71 is online now
Superdave71 is gaining momentum as a positive member of FTE.
Correct me if I'm wrong, but on the 11-14's since there was no switch, they were on all the time by default.
Quick Reply: Does anybody drive with their exhaust brake on all the time
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
