Ignition help PLEASE - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 06-04-2018, 04:29 PM
1ocalalabs
1ocalalabs is offline
1ocalalabs is starting off with a positive reputation.
Hello. I recently had to replace my ignition switch on the column, finally wore out after over 30 years. The new one worked perfectly until today. When turned to start, I can hear something "click" in the dash, sounds like it is coming from somewhere around the cruise module. Nothing else happens. Starter is new and turns when the solenoid is jumped. So I tried putting current directly from the battery to the peg on the solenoid that the ignition switch is supposed to power when turned to start.... motor started turning. So I then checked the red w Lt Blue wire that is supposed to feed power to that peg on the solenoid when in start position, and NO power. So, is there a relay of some sort under the dash, inside the cab that has gone bad? I am illiterate when it comes to reading electrical schematics, so do not know if there is a part that I am unaware of.
Thanks.
Old 06-05-2018, 10:29 PM
g_k50
g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Look at the base of the steering column, there's a switch that's activated by a rod that moves parallel to the column, up and down the column. When you turn the key this rod causes the switch to be activated, sometimes the metal part inside the column breaks and causes the no start issue you are explaining. It's a dorman replacement part but you have to take off the steering wheel to get to it.
Old 06-05-2018, 10:35 PM
1ocalalabs
Sorry, I was holding the switch in my hand and moving the slide with a small screwdriver. The rod and key are not involved. Just for some reason it suddenly stopped feeding power. The column switch checks out fine.
Thanks.
Old 06-06-2018, 10:16 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Thanks.
How did you check the column switch to determine it was fine?
Olbeater
11-01-2010 06:31 PM
BDFD
08-11-2010 11:17 PM
godinski
1999 to 2016 Super Duty
12-04-2007 07:50 AM
wirebrain_8
10-06-2003 07:22 PM
LynnA
03-05-2002 02:15 AM
Quick Reply: Ignition help PLEASE
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
