Who's all towing with their 5.0's? - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2015+ F150
Reload this Page >
2015+ F150 Discuss the 2015 Ford F150
Old 06-18-2018, 10:06 AM
dubster101
dubster101 is offline
dubster101 is starting off with a positive reputation.
Towing my two quads (~2,000lbs total weight with trailer) - easy peasy for the 5.0
Old 06-18-2018, 01:05 PM
johndeerefarmer
johndeerefarmer is offline
johndeerefarmer has a very good reputation on FTE.johndeerefarmer has a very good reputation on FTE.johndeerefarmer has a very good reputation on FTE.johndeerefarmer has a very good reputation on FTE.
Originally Posted by 4wheelfurry View Post
With the airbags I don't even know. It hadles the weight extremely well. Still has a tad bit more wallow than I'd like when say crossing bridges so I need a little more shock. I'm in the process of correcting that now. I have pulled tag alongs as well, the airbags makes pulling so nice! And payload is an afterthought lol Pin weight on my 5er is around 900#. It is supposed to be a 1/2 ton towable unit factory built.
Hitch weight unloaded is more like 1700-1800 lbs and probably 2100-2400 lbs loaded, a far cry from your 900 lbs.
Now I am not the weight police as I tow very heavy stuff with my F150 but if you think your pin is 900 lbs you need to put it on a scale.
Old 06-18-2018, 02:16 PM
johndeerefarmer
Now I am not the weight police as I tow very heavy stuff with my F150 but if you think your pin is 900 lbs. You need to put it on a scale.
Old 06-18-2018, 02:38 PM
ecoboost12
ecoboost12 is offline
ecoboost12 is gaining momentum as a positive member of FTE.
I have to chime in here I agree with you I would like to see what the scale says I think the Decimal is in the wrong place and the Pin weight is Double
I have to say this I think F 250 is calling out!!!
Old 06-18-2018, 03:01 PM
Rickyrobert's Avatar
Rickyrobert
Rickyrobert is offline
Rickyrobert is gaining momentum as a positive member of FTE.Rickyrobert is gaining momentum as a positive member of FTE.
Not much, but i do tow a popup trailer. 2k lbs. Pics soon.
Old 06-20-2018, 05:25 PM
cbradford's Avatar
cbradford
cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
Towed my sons 32 TT about 80 miles home, his other brand was having issues. Trailer is about 8000 lbs, did better than expected since my son was towing with a 2500HD. As mentioned the 5.0 likes the 3k to 4K rpm range and lock out 6th gear. My only complaint was with tow haul mode and compression breaking, so went to manual mode so I could control. My 2017 has 2050lb payload package with integrated brake controller and at full payload can tow 9100lbs.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
