1990 f150 w/ 300 6 - crank no start *SOLVED*
The fuel pump relay gets it power from the fuse link at the starter relay for its common pin over the yellow wire.
The fuel pump relay gets it power from the EEC Power relay for its coil over the red wire.
No power from the ecm to the fuel pump.
The ecm only grounds the fuel pump coil.
Attachment 285111
Attachment 285111
I used a test light on the coil, I have steady 12 V in the one wire connection (2) and also with the two wire connection (1) on the coil. When cranking the engine shouldn't the light blink on the two wire (1) connector?
Also I can hear the two relays that are on the inner fender by the master cylinder clicking but I don't hear the fuel pump.
It doesn't blink while cranking, just has a steady 12 volts. The distributor in it is new so the previous owner probably got as far as I have, determined it was the ign module in the distributor, replaced the distributor, and it didn't fix it. I do have fuel pressure now at the rail so all I need is spark.
Spark Output (SPOUT): Desired spark timing information sent from the EEC to the ICM.
With the SPOUT out of the circuit the engine will run on base timing.
The SPOUT signal, short for SPark OUTput, is a digital signal generated by the EEC-IV processor providing spark angle information to the TFI-IV module. The SPOUT signal on the push start system controls only the firing of the coil. The falling edge of the SPOUT signal is ignored.
In the case that the SPOUT signal line opens from the EEC-IV processor, the TFI-IV module will use the PIP signal to fire the coil. This results in a fixed spark angle of and fixed dwell.
