Debating on buying a used 390 for my 74 F100 Project
So, one thing I thought about today at lunch... I do not own a compression tester.
No big deal, I still have lots of time before I get home from work. Searching on Amazon, I see many kits ranging from $25 - $75. What is everyone else using?
I have no problem spending money on a quality tool, but I also understand not always spending top dollar on something that will not see much use.
Looking for input, what are your thoughts?
Thanks in advance.
Thanks in advance.
It's not just a compression test you need to do, you need to run a 'leak down' test to make sure your not leaking through a valves (intake or exhaust). Where is the popping noise coming from, EFI or exhaust? The idea of pulling one plug wire at a time and replacing it each time before you move on to the next one,,, is a good start. Than you know its popping under ignition. At least you'll know where to focus on when doing the 'leak down' test.
I watched a mechanic pull the wires off one at a time to find where the miss was. I had a miss in my 69 SS350 Camaro, and I tried that pull the wire off and it sounded like some one fired a 30-06 in my ears, my fingers were num and blacken and the neighbors came out to see what happened and all they saw was me holding my hand and teaching them all some new language.
No disrespect for those folks it works for, it's just not for me...
They made a set of insulated spark plug wire pliers for that years ago.
The newer electronic ignitions are hotter with the spark jumping farther increasing the chances of getting bit when pulling the wires by hand.
Was working on a brothers HEI Chevy once, told him to get me a screw drive I could use to lift the wires with, didn't notice he'd handed me one with the steel shank extending thru the handle
Man that thing lite me up when he started the engine.
I was bit hard enough when I was younger, that I adjust timing with a wooden dowel, I refuse to touch the distributor when the engine is running. Yep, chicken I are...
You and me both ! I won't touch one unless absolutely necessary while running. Especially a Duraspark setup. I've seen them throw a spark 3-4 feet.
It's all in how you do it. You first pull the plug wires off and stick them back on so just the boots hold the wires in place but still make sure they are pushed on far enough so the wire is touching the plug tip. Do this with the motor OFF. The tool you need is a long handle spark plug plyers. You can get them at your local Harbor Freight. If your still a little shy, use a pair of those long rubber gloves like the ones you use for your parts cleaning tank.
And YES I've been zappppped a few times but I quickly learned over the years what works.
AK FORD GUY
06-04-2018 02:42 PM
mktsc
22
12-16-2011 12:50 PM
YoungMT Hick
03-18-2010 05:28 PM
Fast_On_Race_Day
11-02-2009 02:08 PM
390 guy
12-11-2003 10:52 AM
