2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Installed Ford Remote Start on 2018 XL
  #76
Old 02-22-2019, 06:19 AM
hlozano's Avatar
hlozano
hlozano is offline
hlozano is gaining momentum as a positive member of FTE.hlozano is gaining momentum as a positive member of FTE.
Another successful install
Thanks to this thread I successfully added remote start to my 2018 F350 CC diesel. I ordered the Ford JS7Z-19A361-A Vehicle Security System from Amazon which came from Fairway Ford for $179. Jumped into Forscan and made the following changes.
Load the BdyCM module and set the highlighted values to Enabled. Write, turn key off then back on. The Remote Start will now appear in your console under Advanced Settings->Vehicle.
Load the IPC module and set the highlighted values to Enabled. Write, turn key off then back on. Climate Control and Seats now appear in the menu under Remote Start.
It took less time to install then converting my headlights to LED's. Thank you all for the information. I always learn a lot from this forum.
  #77
Old 04-29-2019, 08:52 PM
deez904
deez904 is offline
deez904 is starting off with a positive reputation.
Has anyone successfully done this in a 2019 250 xlt? I keep reading forscan doesnít work on the 19 models...
  #78
Old 06-04-2019, 10:35 PM
traveldawg
traveldawg is offline
traveldawg is starting off with a positive reputation.
I have a 2018 Lariat that has remote start (on FOB press LOCK and 2X twice and truck starts).
Can I install Part No: JS7Z-19A361-A (VSS Ford Perimeter Plus) without using ForScan (or dealer) to enable it?
  #79
Old 06-04-2019, 11:38 PM
CenTex Booger Eater
CenTex Booger Eater is offline
CenTex Booger Eater is starting off with a positive reputation.
Interested if anyone has installed on a 2019 F250 STX
  #80
Old 06-08-2019, 09:52 PM
traveldawg
bumping for CenTex and I.......
  #81
Old 07-12-2019, 03:20 PM
Czubek
Czubek is online now
Czubek is starting off with a positive reputation.
Originally Posted by NorEasterMA View Post
I have both. Fob "lock-unlock-lock" sequence starts the truck as does my iPhone app. Best of both worlds. FWIW in the three installs I've done with this VSS module (one 17 and two 18's) all required the jumper to be in place for everything to work.
I just had the remote start installed at a "local" Ford dealer, as part of a purchase of a 2017 f-250 XLT SD. I tried the "lock-unlock-lock", that doesn't work. The remote start fob works well, though.
I looked under the dash and located the module with said jumper installed. There are also, what looks to be two other empty connectors, one blue and one white, which are beside the plug with the jumper.
The dealer installed: EL3Z-19G364-B remote start, FT4Z-19A361-A electronic module and HC3Z-19G366-A sensor assembly. The later being a hood switch, which I see no evidence of, but the "hood ajar" warning shows when I pop the hood with the key on.
I would like to just use the one key fob, with the "lock-unlock-lock", though.
Brian
  #82
Old 07-12-2019, 07:54 PM
markusarealuis's Avatar
markusarealuis
markusarealuis is offline
markusarealuis is starting off with a positive reputation.
I have a 2019 F250 STX, and remote start sitting in my garage. I have not tried to install it yet, but I can't image it not working on the 2019 models.
And to answer another persons question: FORScan doesn't work on 2019. This is not true, I used FORScan extensively for installing an 8" cluster in my truck. I had to change multiple settings in my IPC using FORScan and it performed flawlessly.
  #83
Old 07-13-2019, 05:28 PM
markusarealuis
Booger Eater (lol), I just installed the remote start on my 2019 F250 STX and it works like a charm. Went into forscan and enabled the BdyCM and everything is working perfectly. While I was in there I also added the Def Filter % coded to add it to my display. Currently itís at 55%
  #84
Old 07-13-2019, 06:09 PM
markusarealuis
How to get to this screen in Forscan ?
okay, I am relatively new to Forscan and I have installed this remote start and it works great using the proper coding in BdyCM and IPC. However, I would love to know how to get to the above screens so I can have it displayed on my cluster. Can someone give me instructions on how to get to these screens ?
Never-mind, I figured it out needed to go to plain English mode.
  #85
Old 07-13-2019, 07:57 PM
NorEasterMA's Avatar
NorEasterMA
NorEasterMA is offline
The Lighting Guy
NorEasterMA has a very good reputation on FTE.NorEasterMA has a very good reputation on FTE.NorEasterMA has a very good reputation on FTE.
Here's a funky situation that I wonder if anyone has run into - I have the 12volt.solutions module (which I've got on good authority as being the ford module) and then I have the OEM remote access kit in. It has always enabled me to start the truck either with the lock/unlock/lock on the key fob or with the app on my phone. Everything worked fine for over a year and a half and then the other day I go to start it with the key fob and the lock/unlock/lock sequence doesn't start it up anymore, but it does prompt the parking lights to flash 3 times, then 2 times. Weird right? The app starts it right up. Anyone run into this?
  #86
Old 07-13-2019, 09:43 PM
CenTex Booger Eater
Thanks! Truck is in the shop right now but hope to get it back Monday. Will have to start on my mod wish list again.
IB Member Support
Newsletter Archive
05-18-2018 01:53 PM
SNIPER168308
General Diesel Discussion
12-06-2011 12:23 PM
SNIPER168308
10-05-2011 06:47 PM
SNIPER168308
Electrical Systems/Wiring
10-02-2011 06:52 AM
Quick Reply: Installed Ford Remote Start on 2018 XL
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
