'84 F-250 Carb Spacer Plate issue
1984 F-250 351 2bbl with 94k,
While doing a tune-up it was suggested to go through the carb, now there seems to be an issue with
the spacer plate not fitting correctly. Ford Part # E4TE-9A589-FA
Anyone run into this issue ? The shop keeps saying it has to be modified for the electronics ?
Thanks for any insight
To the best of my knowledge it's all OEM this is based on the son in law of the estate, the P/O was a Ford guy @ a Texas Dealer
The boy's @ the shop gave me the number off the plate, it's cracked next to one of the bolt holes it's like a poly type material
and without a seal it mis-fires
This was the part # I actually took off the OEM spacer plate as they are having an issue finding one, seems the aftermarket ones are causing the issue with electronic do hicky
I looked on ebay, no one has any, no Ford dealer or obsolete parts vendor has any either.
Is this it?
https://www.ebay.com/itm/1984-86-FOR...cAAOSw5Oxa6Ol0
Looks like it has a mount for the EGR on the back, and some hose connections on the front.
Your truck is totally original, everything is hooked up and working, and it has to pass underhood inspections where you live?
Thanks for your input
OP has a 1984 F250 351W 2V .. See post #3 .. OP's original is E4TZ-9A589-F (marked E4TE-9A589-FA)
almost wondering if the crack on the poly spacer occurred when the rebuilt carb was installed, sadly we know that dog won't hunt.
Is this it?
Oh yeah we have the emissions deal, one of the reasons I considered this unit was it has current plates until 12/18 and this is why I took the
opportunity to tune it up so it would pass again. it seemed to run pretty well but it had champion plugs and the plug wires were very dry rotted.
here in AZ anything above a 1/2 truck has to go through the sniffer every year as the 1/2 ton's you can do it for two years.
Nope, it's a poly type material and it's about an inch thick nothing hanging off of it.
