Modular V10 (6.8l)
Dual Battery Setup
Old 05-31-2018, 05:50 PM
rprice
rprice is offline
rprice is starting off with a positive reputation.
Dual Battery Setup
I am looking into putting a second battery in the truck (2003 F250SD, SC, V10). There are a few aftermarket kits available and just wondered if anyone else has done this. Couple of questions:
*Where is the vapor canister relocated to?
*Can the factory battery tray used with the 7.3 diesel be used?
Thanks for any help.
Ron
Old 05-31-2018, 07:24 PM
Mike189677's Avatar
Mike189677
Mike189677 is online now
Mike189677 has a very good reputation on FTE.Mike189677 has a very good reputation on FTE.Mike189677 has a very good reputation on FTE.Mike189677 has a very good reputation on FTE.
I would suggest using an e series battery box and mounting the battery under the cab instead. There is a guy here that used one to add a 3rd battery to his six liter and it worked very well I think it’s a better option than what your thinking currently and the eseries battery box can be had pretty cheap.I’ll post a link to his thread if I can find it. Well that was easier than I thought. Here’s the link.
https://www.ford-trucks.com/forums/1...tallation.html
Old 06-01-2018, 09:17 AM
rprice
rprice is offline
Mike189677,
Thanks for the info and the link - LOTS of very good information and ideas and links to other related threads. I like the convenience of having the second battery under the hood but the position of the air intake/filter assembly and fuel vapor canister takes up most of the space on the driver's side, making the frame mount simpler.
Old 06-02-2018, 06:16 AM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
wiskeyVI is gaining momentum as a positive member of FTE.
I've been watching the E series battery boxes on ebay, off and on. Prices seem high most of the time.
There's a gentleman on the Expedition Forums that is/was working on an add on battery box design.
Last I saw, he had installed it and took it for a test trip. I haven't seen a follow up yet.
Old 04-28-2019, 02:44 AM
darkjedi351's Avatar
darkjedi351
darkjedi351 is offline
darkjedi351 is gaining momentum as a positive member of FTE.darkjedi351 is gaining momentum as a positive member of FTE.
Ron
almost a year later but here's one kit that works. it's spendy but its all there.
https://www.dirtyparts.com/store/det...FORD/pid-80434
cocot
1968-2013 Full Size Vans
04-23-2004 11:56 PM
sdunham
1999 to 2016 Super Duty
07-07-2003 09:26 AM
SplashMan
Electrical Systems/Wiring
05-22-2003 10:13 PM
tr8727
01-12-2003 02:18 AM
jon69f250
09-17-2001 12:17 PM
Quick Reply: Dual Battery Setup
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
