occasionally do not hear the fuel pump when starting the van?
I will study on this a little more and get back to it tomorrow evening. Its good to know my diagrams are no good so I wont waste time tracing down circuits that don't exist!
Was thinking that if and when it does this again, I would need to check both the power and ground circuit on the FP relay.
Since I don't have a correct drawing.. The FP relay gets it power from a 12v fused link that perhaps comes from the starter relay probably not the problem?
The ground for the FP relay comes from the EEC. pin #22 IF it has both 12v power and a ground then it could be the relay or pump in the tank. If it has no ground it would be either a problem in the circuit or the EEC?
I was wondering if a person could temporarily connect a LED light someway to the power and ground to the FP relay and be able tell if the relay is energized or not the next time I don't heat the pump run. I could use a short wire and route it out between the hood and fender on the outside of the van so I could see it...
It is not always very convenient to just jump out with a test light and I would have a problem holding the test light over on the relay while turning the ignition switch...
The fuel pump relay supplies power to both the HP pump on the frame and the fuel pump in the tank.
So if the frame HP pump runs the fuel pump relay, pin #22 ground and the inertia switch are OK.
Also the fuel pump in the tank and the fuel gauge sender in the tank have a common ground along with the pump on the frame.
Thank you for the help and wiring schematic Subford..
I am going to check my manuals and see if there is any way there could be a problem with the ignition switch. Perhaps the circuit that feeds the EEC relay from the ignition switch. I will pay closer attention to what is going on the next time I do not hear the pump.
The pump should be pretty quiet, when they get noisy enough to be obvious is when you start keeping an eye on it, and to do that a gauge on the fuel rail works really well. Are you not telling us the whole story? You say the truck starts no problem but does that mean first turn of the key it fires right off or do you have to try it several times? Firing on the first turn means you don't have a problem.. stop worrying about it, but if it's taking several tries then yes the pump is on it's last legs so you are correct and it needs to be addressed.
Mine too started getting noisy when the key was cycled on. It also took an extra second to start which was unusual. It failed towing a trailer and definitely made for a bad day. If you don't want to get stuck, you may consider changing it before it leaves you stranded!
Well since the thread was started back... Here it is over 2 years later and the van is still running and I always hear the in tank pump come on but hardly ever hear the HP pump under the drivers side. I did acquire a Motorcraft HP pump at a really low price last year just in case this one were to go out.
Couple more thoughts here. The van had sat for years and needed a new tank, sending unit, pump, and filter. Perhaps it had some junk in the HP pump causing the noise and it cleared itself.
I used to own a 1990 Mercury Colony Park Wagon with a 5.0 engine in it. It had a single in tank pump that pumped about 45psi and did not need the HP pump. The wheel base on the Colony park is 114" compared to my E150 at 138" but that is still pretty long as the fuel tank on the CPW was behind the rear axle. So I wonder if the rear tank pump in the van could supply just enough fuel to run a 5.0
My next group of work is greasing the speed odometer which requires raising the van to loosen a clamp holding the odometer cable in place, in order to gain enough slack on the cable to pull out on the instrument cluster. But that will be a good time to check the load on the hp pump. The bad think about running boards is that you have to lift the van to get under it!
cityjack
07-13-2013 03:22 PM
solidmetal
04-23-2007 08:36 PM
wrangler
09-28-2003 07:58 PM
