Towing with F-350
Towing with F-350
I am buying a 26,000 pound gooseneck food trailer and want to make sure I am getting the correct truck to haul it. Total GCVW is going to be ~34,000 lbs.
I am getting a 2018 F-350 XLT Super Duty with 11,500 GVWR package, 6.7L PS Diesel engine, 3.55 gears, and gooseneck hitch. I believe I am rated correctly up to 27,500 pounds.
Without modification, am I okay?
I haven't towed anything this heavy in a long, long time since I was driving 915s in the Army.
Last edited by misfitclt; 05-30-2018 at 04:21 PM. Reason: Updated some information to be clear.
For that kind of weight, if it is something you are going to be towing regularly (which I would think you are since it's a food trailer), I would go with the F-450. You get the upgraded brakes, axles, and shorter turning radius. At a bare minimum, I would get the dually F-350 with the 4.10 rear end.
Most states do not require a Class A when driving/towing RV's. Alabama doesn't require a Class A.
If you see a sign that says Bison on Highway, believe the sign. And any sign you see that says moose crossing.
Go ahead and fix you up a sign to hang in the Sign Post Forrest.
I want to make the trek again one day.
A crew cab 350 DRW 6.7 with 3.55s has a GVWR of 14,000lb, GN rating of 27,300lb, and a GCWR of 36,000lb. You should be within all of these limits. Not sure about your called out GVWR above. The 350 should be able to handle it all day every day.
Still need a Class A license, too.
Yep, and post the pic in the "what do you pull" thread of mine....We love seeing these things work.
Update.
Towed the trailer back from Oklahoma with no issues. Truck is green so MPG started at 8.0 mpg over first 100 miles but by the end of the trip I was running 9.4 mpg. Should get a little better I would think over time.
The 4.10 gears and 14,000 GVWR package were both better that the 3.55 and 11,500 GVWR would have done. I knew it was back there but had no problems and could accelerate on uphill inclines of 5% if I wanted.
The "Ultimate Tow Cameras" are outstanding. I use line of sight most of the time but having the option to confirm with the cameras is an outstanding and helpful feature for ease and safety. Checking on adding camera to rear of trailer as well.
This being my first dually I think I am forever ruined for any other trucks. My F-150 now feels like a Tacoma.
nvetro
2017+ Super Duty
130
07-14-2019 07:27 PM
visceral
2017+ Super Duty
56
02-04-2019 06:22 AM
Doonz
1999 to 2016 Super Duty
08-09-2012 02:42 PM
derherr65
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
02-25-2006 09:28 PM
