Researching 2018 Expedition Towing configuration...
We are looking to up size our SUV from a Highlander to the Expedition so I am researching the various configurations. Although we have a 2017 F250 for towing I would like the Expedition to be able to tow. I understand the towing and heavy duty towing options available. What isn't made very clear is what configurations if any comes with an installed wiring harness (Plug) and a hitch receiver. If you have information regarding this it would be appreciated. Any other general thoughts on the 2018 Expeditions would be welcome.
Thanks!
Jim
Thanks!
Jim
[QUOTE=Nimrod;18010238] I would like the Expedition to be able to tow. I understand the towing and heavy duty towing options available. What isn't made very clear is what configurations if any comes with an installed wiring harness (Plug) and a hitch receiver./QUOTE]
Class IV trailer hitch and 4 and 7 pin connectors are standard on all XLT's and up (did not look at the SSV or XL trim, sorry). From the Ford brochure:
But you probably also want this:
STANDARD FEATURES 2018 Expedition: Mechanical 4-wheel independent suspension, Class IV trailer hitch receiver with 7- and 4-pin connectors, Electric power-assisted steering, Power 4-wheel disc brakes with Anti-Lock Brake System (ABS),Trailer sway contro
Heavy-Duty Trailer Tow Package, MSRP $1570
-inc: Integrated Trailer Brake Controller, Electronic Limited Slip w/3.73 Axle Ratio, Pro Trailer Backup Assist, Heavy-Duty Engine Radiator
My '17 also has load leveling suspension, but I do not see that listed as an option on the '18s.
[QUOTE=jschira;18010378]
Thanks good info. I do not have a brochure yet. I was looking though configuration options and didn't see that. Could be because it was more basic and standard. How do you like yours?
[QUOTE=Nimrod;18010395]
.pdf of the brochure can be downloaded at Ford.com.
I have only pulled 6000 lbs once and 4500 lbs 3-4 times. No sweat. Put 'er in "D" and hit the pedal.
schultzd
2015 + Expedition & Navigator
11-27-2018 03:11 PM
theoldwizard
09-14-2015 07:15 AM
MADEXP
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
09-21-2011 02:52 PM
tpetty
Car/truck Buying Advice
10-26-2004 05:09 PM
