'17 3.5 Eco, oil pan leak
Its funny. My '11 6.7 came with a composite.
In '12 they went back to stamped steel.
The '18 F150 5.0 I rented has a composite.
Drain plug looks to be aimed right at the sway bar.
5.0 guys won't like that.
I hope your right and the aftermarket responds with something better.
Even a better sealant would work.
I have not heard anyone say the tranny pans have an issue yet.
I really wonder what the root cause of all these oil pan leaks turns out to be. Composite oil pans are nothing new...heck, the Detroit Diesel Series 60 used them for over a decade until it left production a few years ago. Why are these ones not sealing?
I'd guess it has more to do with the sealant than the material of the pan itself.
I know Permatex makes a Gasket Material that's called The Right Stuff its being used in Place of a Gasket
Its a Gray One Minute Gasket that doesn't contain any of the Silicone RTV that has been used for years
That's why the Dealer needs 3 Days for the Silicone RTV to cure do you think they are paying about
10 to 15 bucks a Kit, I have done allot of Engine work and all of these newer oil pans and Valve covers that don't use gaskets
anymore,I really think the Dealer needy to know about the Fine Permatex product that can do 2 to 4 Gasket Applications.
I really think the dealers are only authorized to use the Motorcraft sealant specified in the workshop manual. Anything else could make them liable for a chargeback in the event of a failed repair. Do you know what the specified sealant is? I don't have the service manual, how do you know they're not using the same product?
New Gasket Maker
https://www.permatex.com/products/ga...t-grey/#buynow
Here's the Site for the Info for the Gasket Maker
