E40D TO ZF5 7.3 WIRING DIAGRAM - Ford Truck Enthusiasts Forums
Old 05-26-2018, 02:02 PM
farmerbrown00
farmerbrown00 is offline
farmerbrown00 is starting off with a positive reputation.
HI, i am looking for a wiring diagram for the zf5 speed swap. I have a 96 f350 7.3DIT with e40d. My parts truck is a 94 idi with 5 speed. i saved the wiring off of the 5speed to use on the 96. i would also like to use the auto pcm. thanks
Old 05-26-2018, 03:47 PM
green_95
green_95 is offline
green_95 is starting off with a positive reputation.
I did the exact swap with a idi to my 7.3 powerstroke about 1.5 yrs ago. I kept my auto pcm and used my auto harness, I left the transmission range selector switch on the truck and left it in the neutral or park position and it starts by the key, you just loose your cruise control. Or you can un hook the transmission range selector and just jump the wires for neutral or park together. I did cut plug ins for backup and 4x4 lights off the manual harness and wired them up, and they work fine.
Old 06-06-2018, 09:57 AM
lee00
lee00 is offline
lee00 has a great reputation on FTE.lee00 has a great reputation on FTE.lee00 has a great reputation on FTE.lee00 has a great reputation on FTE.lee00 has a great reputation on FTE.
Any ideas on if there is a way to keep the cruise?
Old 06-06-2018, 09:09 PM
green_95
green_95 is offline
no idea really. I thought if you put a toggle switch in the truck for the 2 wires that put the truck in park to start by the key, and once it is started by the key, flip it off and have another toggle switch for the 2 wires that put it in drive. I haven't tried this. No idea if it would work. The wires I'm talking about are on the transmission range selector switch. Hope this makes sense.
Old 06-07-2018, 08:23 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Jarrett Campbell is gaining momentum as a positive member of FTE.
You could use just one DPDT switch and it should work the same as what you described with two switches.
Old 06-07-2018, 10:21 AM
green_95
green_95 is offline
I think it would work, because with the transmission range selector switch in park to start by the key, the pcm thinks the truck is still in park while your actually driving so ur cruise won't work in pwrk. But once the switch is flipped to drive, boom cruise should work. I'm just afraid that once it's flipped to drive that it might burn something up.
Old 06-08-2018, 07:39 AM
lee00
lee00 is offline
Wouldn't it just be easier to reprogram the pcm?
Brian Donoghue
05-02-2017 03:13 PM
arkredneck
17
11-26-2015 09:19 PM
f300i6
08-07-2014 05:25 AM
hagerty_justin
02-05-2011 08:12 AM
wycowboy
12-01-2004 10:26 PM
Quick Reply: E40D TO ZF5 7.3 WIRING DIAGRAM
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
