Engine Assembly - Sealant and Lube
Hello everyone. I was reading through my Factory Service Manual (FSM) - and trying to compile a complete list of sealants and lubricants that I will need for engine reassembly. This is not complete engine reassembly, but the parts of the reassembly that require a sealant or lube. I wanted to compile my findings in this thread to see if my understanding is correct, if the equivalent sealants/lubricants to the Ford numbers are correct, and to find out the missing equivalents, and if I'm missing/forgetting anything else. Hopefully I'll have the answers within the 30 day limit so that I can edit this post with all of the information. Please take a look! Thanks
Sealants and Lubrication are listed in likely order of reassembly.
Crankshaft
Piston and Rings
Push Rods & Rocker Arm Assembly
Push Rod Cover
Crankshaft Rear Oil Seal
Oil Pan Side Gaskets
Core Plugs
Water Pump
Intake and Exhaust Manifolds
Flywheel Attaching Bolts
So what do ya'll think? Can you fill in the gaps where I don't have an "off-the-shelf" equivalent? Are the other equivalents correct? What am I forgetting about? Thanks a lot!
Crankshaft
- Medium: Engine Oil Equivalent: None Application: light coat of engine oil on bearing journals and bearing halves.
- Medium: D6AZ-19562-B Equivalent: Permatex Ultra Black® Gasket Maker Application: see images below
Rear Main Seal
- Medium: Engine Oil Equivalent: noneApplication: See image below
- Medium: Engine Oil Equivalent: NoneApplication: Oil the piston rings, pistons, and cylinder walls with light engine oil prior to assembly.
- Medium: Engine Oil Equivalent: NoneApplication: Oil the camshaft bearing journals prior to assembly.
- Medium: D0AZ-19584-A (polyethylene grease) Equivalent: off-the-shelf Engine Assembly LubeApplication: Apply to all lobes
- Medium: D0AZ-19584-A (polyethylene grease) Equivalent: off-the-shelf Engine Assembly LubeApplication: see image below
- Medium: Engine Oil Equivalent: noneApplication: see image below
Push Rod Cover
- Medium: B5A-19554-1A (oil-resistant sealer) Equivalent: Permatex "The Right Stuff"Application: see image below
Cylinder Block Front Cover
- Medium: C1AZ-19590-B Grease Equivalent: ???Application: Front cover crankshaft oil seal. See image below
- Medium: D0AZ-19584-A (Polyethylene Grease) Equivalent: ??? Application: Crankshaft stub, damper hub I.D., and seal rubbing surface of front cover (see image below).
- Medium: B5A-19554-A Equivalent: Permatex High Temperature Thread Sealant Application: see image below
- Medium: D7AZ-19B508-A Equivalent: ??? Application: see image below
- Medium: D8AZ-19554-A Equivalent: Permatex High Temperature Thread SealantApplication: see image below
- Medium: B5A-19554-A Equivalent: Permatex Water Pump & Thermostat RTV Silicone Gasket Application: see image below
Water Pump
- Medium: B5A-19554-A Equivalent: Permatex Water Pump & Thermostat RTV Silicone Gasket Application: Gasket (both sides) and bolt threads. See image below
- Medium: Graphite Grease Equivalent: ??? Application: See image below
- Medium: D8AZ-19554-A Equivalent: Permatex High Temperature Thread Sealant Application: See image below
Last edited by 81F(ranken)100; 05-29-2018 at 09:36 AM. Reason: Added Polyethylene Grease to "front cover" installation procedure.
For the graphite lubricant, you could use standard anti seize. For the poly grease, i normally use blue chassis grease or sil glide for light oil seal lubricant. I couldn't agree more with this being a sticky.
Nicmike
09-29-2020 03:20 PM
JoeDaf
03-03-2018 10:46 AM
racsan
04-28-2011 10:00 PM
79F150EFI
08-27-2007 06:33 PM
