XLT to King Ranch Interior Swap
Asking to see if anyone’s ever done a total model swap to a f250. I currently have the 2010 f250 xlt model with the cloth seats and I’m wanting to put the the king ranch complete interior into it. Basically, I’m curious if everything will match up in the dash with the electronics and whatnot. The temperature control area is different and a couple other things. I would assume it would be a direct replacement, however I wanted some opinions. Thanks
I would think that the HVAC controls would be the biggest issue. I would have to believe that the plugs would not be the same. The rest should just swap in.
I would love to dump the Lariat interior in my 09 for a King Ranch interior. You will have to keep us updated.
Easier said than done, i paid 32k for mine with 45k miles on It. There is no king ranch with that miles for that price. It’ll have 100k plus and people will still try to get 30k. And the only thing I’m going to pay to have done is the dash. Other than that it’s a easy swap, just time consuming
Before
Gutted and door panels in
Everything in besides the dash and steering wheel. Now trying to figure out how to get power to the driver seat. Apparently since the king ranch had memeroy seats and mine didn’t you have to bypass something in the wiring to make it work. So, that’s where I am now
Looks good. I know that the AC controls in the 11-16 trucks can be directly swapped between trim levels. The wiring harness is exactly the same. I'm assuming it is the same with your truck since it has the same dash.
The only negative is that the dual zone control doesn't work if the truck didn't' already have it. The entire display will light up and all functions including mirror heat, and defrost, etc. will work, but the dual zone control doesn't work. The passenger **** can be changed and the temp display will change, but it doesn't actually do anything. The drivers side **** controls it all. There is an entire thread on this.
And no, mine didn’t have climate control. So I guess I’m out of luck on that. It’s currently in the shop right now having the dash swapped. Better them than me to figure it out
