Side Windows
Side Windows
I'm replacing all the glass in my truck. I'm looking at the one piece side windows. they come in a kit with weather striping and are cheaper than the regular glass and buying the weather strip separate. I do like the vent window but i'm looking at cost. Has any body used them Good / Bad ?.
The kits show the channel around the glass and the felts that go across the top of the doors. It eliminates the rubber weather strip at vent window. With the parts I need for mine the one piece glass save about $100.00 per side. Still waiting for some input on someone that has done it to this style cab.
https://www.ford-trucks.com/forums/1...0-build-6.html
This guy put them in his. He's got a very cool build going on too!
Below is a quote from a thread on the HAMB regarding this same subject.
I thought I remember seeing an article somewhere that sort of detailed this, but I can't find it, so it is possible I was thinking of something else.
I am interested as well, but love the nostalgic look of the vent windows.
Jeff
I'm sorry that I didn't see your post earlier. I did the Sac Ford 1 piece window kit on my 57 F100. I love the look of it and now that it has broken in a little the windows work great. I wouldn't say they are EASY to put in though. You have to use a hack saw down into the window opening to cut out a channel for the window to sit. It is super tight and hard to do. If your truck is painted like mine was I would suggest LOTS of masking tape to protect the paint. The only other thing is the brackets they give you to hold the bottom of the channel were kinda cheesy so I made my own that bolted to the tab that the original window stop bolted. If you have some mechanical ability they are not hard to install though. No welding unless you make your own brackets. I think it was worth the money. Those trucks have very small factory windows and I LOVE having the 1 piece. Hope this helps.
Jeff
dave boley
23
10-12-2008 03:37 PM
56Jeff
08-14-2006 08:56 AM
galaxy5oo
02-03-2005 07:04 PM
maximumhorsepower
24
11-22-2004 10:11 AM
