Cleaning iron 4bbl intake - Ford Truck Enthusiasts Forums
Old 05-22-2018, 09:42 PM
Jghake
Jghake is offline
Jghake is starting off with a positive reputation.
Hey guys. I picked up an iron 4bbl intake on Craigslist today and need to start prepping it to go on my truck.
Do you think a vinegar soak would get all the rust out of the inside of the manifold? What are your best recommendations for getting it ready?
Old 05-22-2018, 09:48 PM
James Wagoner's Avatar
James Wagoner
James Wagoner is offline
85 Bullnose F-250
James Wagoner is starting off with a positive reputation.
If you are feeling adventurous enough, you could make an electrolysis tank. I plan to make one here pretty soon for some parts off my donor motor. They are not terribly complicated and would work better (probably faster too) than vinegar.
Old 05-23-2018, 06:17 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.
Thing is it is line of sight so inside the ports will not get clean.
I would have a machine shop hot tank it first before I did anything.
Then either glass bead it or try electrolysis and go from there.
Dave - - - -
Old 05-23-2018, 06:43 AM
Eddiec1564
Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Dave - - - -
Actually electrolysis tank will get inside the ports. My Dad had done his tractor intakes and heads in the tank he made. They all came out nice and clean. We verified with a bore scope too.
I have seen others do electrolysis on engine blocks with very good success in getting the oil passages cleaned out. They used a pump to intermittently flow the fluid through the small passages while the block is being zapped.
Old 05-23-2018, 09:18 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
If it's not loose rust or dirt, I would not worry about it. I would take a wire wheel on a drill and clean where the carb and intake gaskets go, spray a little wd40 on the inside passages and wipe them out as good as you can with a rag, and run it. What harm will a little rust staining do, as long as it's not so bad that it flakes off?
Old 05-23-2018, 12:17 PM
James Wagoner
85 Bullnose F-250
Dave - - - -
Hot tanking for sure! Not sure on costs, but homebrew electrolysis tank might be cheaper depending what parts you have on hand to begin with.
Old 05-23-2018, 01:52 PM
Tedster9's Avatar
Tedster9
Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Mollasses (about a 10% solution in water) is another excellent method. It won't cut through paint or grease, but it works great for rusty parts and tools.
Old 05-23-2018, 03:15 PM
81F(ranken)100's Avatar
81F(ranken)100
81F(ranken)100 is offline
81F(ranken)100 is starting off with a positive reputation.
I had to look that up on the Google because (I'm sorry) I didn't believe you! That's awesome
Old 05-23-2018, 05:14 PM
Tedster9's Avatar
Tedster9
Who'da thunk it right? Yeah, no it works great. Takes a while sometimes maybe a couple weeks or more, but it's excellent. I've seen pics of people with an old crescent wrench or whatever they found buried in their back yard all fused together, and a few weeks later it's all cleaned up oiled up and nice addition to the tool drawer.
The solution can be reused quite a while and doesn't leave a toxic hazmat disposal problem either. Would be fine as lawn food. Can get a little stinky, definitely an outdoor operation on any kind of scale, like that intake.
Old 05-23-2018, 08:49 PM
whisler
whisler is offline
whisler is gaining momentum as a positive member of FTE.whisler is gaining momentum as a positive member of FTE.
I have seen Evapo-Rust recommended for this type of thing. More expensive than molasses but quicker.
Old 05-23-2018, 09:39 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is offline
82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.82_F100_300Six has a very good reputation on FTE.
Ospho...or naval jelly
Old 05-24-2018, 12:49 AM
Jghake
Jghake is offline
Cool thanks guys.
Anyone have any ideas on how to block off this guy here?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
