Dead in the lot
Dead in the lot
I went to put my truck back into stock mode got back and it won’t start. Seems to have full electrical power but when I turn the key everything normal occurs except the starter engaging.
I checked the number 22 fuse and starter relay both were fine.
Thanks for any help as I await the tow truck.
I didn’t try disconnecting the batteries will give that a try when We drop off in a few minutes. There’s an aftermarket alarm but it’s been disconnected for a long time now. Also it is a 2002 and the starter was replacead a couple years ago autocrap brand yet has been appearing to function properly. Everything apperars in working order including the fuel pump and wait to start light with no codes.
If disconnecting batteries does nothing, then I would be looking at the starter. I know it is difficult, but if you have a multi-meter you could check to ensure it is getting 12v voltage.
Everything seems fine, except the starter doesn't kick over?
Where are you now? Someone may be close by that can offer a hand.
Big Chill
03-01-2011 06:49 AM
WoomaHodal
10-04-2009 08:19 PM
Ponyboychris
75
06-21-2009 10:48 AM
