Spark Plugs: Best '89 5.0 302 choice - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 05-21-2018, 02:43 PM
wcwinans's Avatar
wcwinans
wcwinans is offline
wcwinans is starting off with a positive reputation.
Question Spark Plugs: Best '89 5.0 302 choice
Hi FTE world
I'm looking for peoples input here. I am changing out my spark plugs on the E150 (1989 with 5.0 302 engine) and when i went to the autoparts store they suggested NGK iridium LX spark plugs #7559.
Is this a good choice? What do you use? Which is the Best? Worst? and what is the proper heat range for this van?
Old 05-21-2018, 04:04 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
Clubwagon is gaining momentum as a positive member of FTE.Clubwagon is gaining momentum as a positive member of FTE.
I had a '96 E150 5.0 for many years. I used several brands of plugs but always went back to Motorcraft platinum.
NGK makes great plugs. I use them in both of my Toyotas. Can't imagine they wouldn't be fine in the 5.0.
As a side note: The Motorcraft Platinum plugs would typically outlast the distributor cap and wires.
Old 05-21-2018, 11:41 PM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
My choice, good old standard Motorcraft copper. I don't waste money on the fancy plugs, they don't last any longer than these
Old 05-22-2018, 11:36 AM
Conanski's Avatar
Conanski
Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Motorcraft copper is best. Irridium and platinum will not last and I find the aftermarket brands are hit and miss. Also do not use those plugs with a screw on tip, it's just something else to work lose and create a misfire.
Old 05-22-2018, 03:10 PM
wcwinans's Avatar
wcwinans
wcwinans is offline
Thanks all! How would i check the heat rating on the motor or is that even important?
Old 05-22-2018, 03:48 PM
jeffreyclay's Avatar
jeffreyclay
jeffreyclay is offline
jeffreyclay is starting off with a positive reputation.
If your engine is burning oil you might want your plugs to be 1 heat range hotter to burn the ash left on the plug tip from the oil. Otherwise run the standard heat range.
Old 05-22-2018, 04:09 PM
wcwinans's Avatar
wcwinans
wcwinans is offline
how can i tell what my standard is??
Old 05-22-2018, 04:44 PM
Clubwagon's Avatar
Clubwagon
Do you have a service manual? There will be plug specs there.
I did use the platinum plugs because they do last longer and it was a PITA to change the front two plugs on my van. So the less frequent the better.
Old 05-22-2018, 05:04 PM
baddad457
If you're talking about # 1 & 2 they're easy once you remove the alternator and air box.
Old 05-22-2018, 08:10 PM
Clubwagon's Avatar
Clubwagon
Ha! My van was a '96 5.0. You had to remove the airbox to do most anything. And I could change those two plugs in the time it took to remove the alternator.
Old 05-22-2018, 10:19 PM
baddad457
Little tighter with a 351.
Old 05-22-2018, 11:07 PM
annaleigh's Avatar
annaleigh
annaleigh is offline
annaleigh has a good reputation on FTE.annaleigh has a good reputation on FTE.annaleigh has a good reputation on FTE.
I use the motorcraft copper. The left side is easy to access with the doghouse off.the right side rear 2 are easy to reach. I got the front two in the right side from the right wheel well using a long extension. May have also used a swivel socket.. I also did a compression check at the same time and those 2 on the front right were fairly easy to access from the wheel well. I don't remember if I jacked it up and took the wheel off or not..
Old 05-23-2018, 09:23 AM
Clubwagon's Avatar
Clubwagon
At least on my van, I could reach in over the tire with the extension. Didn't have to jack the van.
Old 05-23-2018, 10:42 PM
wcwinans's Avatar
wcwinans
wcwinans is offline
looks like my gap is 0.042 - 0.046 ASF -24C is the motorcraft copper core they recommended but still couldn't find any heat range info on that
Old 05-23-2018, 10:50 PM
wcwinans's Avatar
wcwinans
wcwinans is offline
https://www.ngk.com/Spark-Plugs-NGK-c593.aspx
and at the autoparts store, it says these ngk parts it my 5.0 302 engine, but theyre listed gap is 0.054 where mine from the sticker above is 0.042 - 0.046
is there something im missing??
Quick Reply: Spark Plugs: Best '89 5.0 302 choice
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
