2000 7.3 white smoke no boost no power
new here. hello everyone.been having problems for a while trying to diagnose this. just changed ebpv pedestal and valve,went with the delete kit. just changed both batteries. white smoke no boost. 1500 or so rpm starts to smoke. smells like fuel. does not stall. did some scans with friends snap on scanner. nothing major came up. but no engine light ever came on.turbo spins nice. no play. just replaced fuel filter new oil and filter and new air filter. truck starts and idles fine. buzz test seems ok. any sugestions? turbo shot? injectors?
2000 f-350 Lariet LE DRW 4X4 auto 4.10 gears .banks dynafact gauges 3 pillar pyro/egt,boost and trans temp.banks six gun diesel tuner,big head wastegate actuator,banks 4" exhaust,banks transcommand shift kit.mag-hytec trans pan.
Do you have boost and/or EGT gauges? Did it have this problem before you changed out the pedestal? If you have an IR thermometer a reading on each and every cylinder on the exhaust manifold could provide some useful information. Have you checked your connections at the UVCH, 42 pin and wire chafing at the 42 pin where the harness rubs on the VC?
Are you sure? That doesn't sound right. MAP should read atmospheric pressure (around 14.7 psi) with key on engine off and go up from there. These engines don't pull a vacuum. I know throwing parts at these trucks can get old, but it sounds like you have a bad MAP sensor. As another poster recommended, check the tube and all the connections to it and swap it with a known good unit if possible.
