2000 7.3 white smoke no boost no power
Old 05-21-2018, 05:44 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is online now
It's a Van Gogh
Fuel pressure needs to be checked under load. Revving in park does not require enough fuel to expose a weak pump or partially clogged in-tank screens. You could rig up something temporarily to test it on the road, but if you're going to keep the truck I'd recommend a permanently installed gauge.
One trick is to blow light shop air back thru the lines from the fuel pump. Open fuel filler cap first. Some good write ups on here for that procedure. If the in-tank screens are clogged that can blow off the crud temporarily.
Old 05-21-2018, 05:28 PM
jaybird38's Avatar
jaybird38
jaybird38 is offline
worse than i thought
Old 05-21-2018, 05:48 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Kc just got there new turbo's in, try a new turbo. KC38R you'll like it. Do you have stock injectors?
Old 05-21-2018, 05:49 PM
jaybird38's Avatar
jaybird38
yes stock injectors as far as i know. the truck had some mods done before i bought it.most was just bolt on stuff.
Old 05-21-2018, 06:07 PM
Bonanza35's Avatar
Bonanza35
If you have fuel pressure under load, moving, then it might be cups. But that turbo will help with stock injectors also. But get some tunes when all is right.
Old 05-22-2018, 03:17 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
whoa Chet, lets not have him move too fast, bud. Firstcthing is, rebuildcturbo with new stock/aftermarket wheel. While doing so, check all your clamps, turbo butt alignment, boots..etc
Old 05-22-2018, 09:27 AM
jws4621's Avatar
jws4621
jws4621 is offline
If that is his turbo wheel I would be worried about No. 8 compression, or possibly pieces of that stuck on the valves.
Do you have any way to run a compression test before you start throwing parts at it?
Old 05-22-2018, 09:51 AM
jaybird38's Avatar
jaybird38
I will check if my friend has one.
Old 05-22-2018, 11:06 AM
HD Rider's Avatar
HD Rider
HD Rider is offline
I highy doubt there are any big chunks in the valves. They would have to get through the intercooler.
Old 05-23-2018, 07:05 AM
jaybird38's Avatar
jaybird38
Pulling intercooer today or tomorrow. Remanned turbo be here soon.
Old 05-23-2018, 05:38 PM
Bonanza35's Avatar
Bonanza35
Should of bought the kit and reman'd your self. I sure wouldn't put a stock turbo back in. What are you using the truck for?
Old 01-19-2021, 12:22 PM
OBS97NEWB's Avatar
OBS97NEWB
OBS97NEWB is offline
Well? What happened?
kefrko
13
10-03-2014 05:37 PM
hydro man 17
09-01-2014 05:12 PM
cylemik
10-15-2011 12:39 PM
harleyjohn45
13
07-01-2009 10:47 PM
brabe
12-02-2003 12:12 AM
Quick Reply: 2000 7.3 white smoke no boost no power
