1955 f-250
  #46
Old 05-24-2018, 10:10 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
No no, you’re thinking Napco. I think the only Fabcos I’ve seen were Fords. And like Chuck said above, generally ‘55 but we do have the one ‘56. But those others pictured and linked don’t look to have the raised cab and clip. Confusing. Stu
  #47
Old 05-24-2018, 10:19 PM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Originally Posted by truckdog62563 View Post
No no, youíre thinking Napco. I think the only Fabcos Iíve seen were Fords. And like Chuck said above, generally Ď55 but we do have the one Ď56. But those others pictured and linked donít look to have the raised cab and clip. Confusing. Stu
oh, wow. I didn't know that. So a Fabco in itself is rare, not just a Ford Fabco.
  #48
Old 05-26-2018, 07:02 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
thundersnow70 is gaining momentum as a positive member of FTE.thundersnow70 is gaining momentum as a positive member of FTE.
Figure out if your front axle is salvageable. Figure out if the t-case works. If you can check those two things off find a donor frame and do a swap. And then speculate for years why the frame was cut and stacked. Another unsolved awd conversion mystery! Just my 2 cents.
  #49
Old 05-26-2018, 08:20 AM
thundersnow70
By the looks of the t-case shift rod I don't think Fabco did that frame stack. Seems to me the bend in the rod came after the stack to make it work with the stack. Fabco would have given more thought to the linkage angle imho.
rpovette
10-01-2006 05:35 PM
scottjo
04-01-2006 07:46 AM
bigskyguy
16
11-27-2004 09:03 PM
F250Rob
09-12-2003 07:10 AM
tongie607
10-25-2002 04:31 PM
Quick Reply: 1955 f-250
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
