Temporary fuel pump power wire - Ford Truck Enthusiasts Forums
Old 05-19-2018, 12:27 AM
krooser's Avatar
krooser
krooser is offline
krooser is gaining momentum as a positive member of FTE.
I'm done screwing with trying to find the source of 'no power' to my high pressure fuel pump. I need to move this truck under it's own power to satisfy the zoning ****'s who have taken over the town. Anything that is parked on the grass (in my case an overgrown gravel parking pad) is in violation and the girl in charge of enforcement visit's my sister's beauty salon across the street every two weeks. I went round and round with them for three months until I got a bonded title for my truck in March. I don't want to see their mugs anymore...
So I'm going to install an on-off toggle switch run from the fuel pump power with to the battery. I'll use 20 amp in-line fuse similar to what I replaced the 20A fusible link with last week.
Anyone see any problems with this? I'll go back to looking and repairing the real problem later...
Old 05-19-2018, 09:47 AM
bdelmar2
bdelmar2 is offline
bdelmar2 is starting off with a positive reputation.
Race car guys do something similar all the time so it should be fine I imagine.
Shortly after I first got my truck running the computer went out and wouldn't run the fuel pump so I got by for a couple days running a ground wire to the test terminal under the hood. Plug the wire in, start the truck, shut the truck down, pull the wire. Kind of a pain, but it worked.
Old 05-19-2018, 12:15 PM
krooser's Avatar
krooser
krooser is offline
I like the way you think...
Old 05-19-2018, 02:06 PM
Mudsport96's Avatar
Mudsport96
Mudsport96 is offline
Mudsport96 is gaining momentum as a positive member of FTE.
Could always put a momentary button on it to start the engine, and have an oil pressure switch that takes over afterwards. That way, if the engine stalls the pump cuts out and doesn't stay running.
Old 05-19-2018, 06:47 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
vjsimone is gaining momentum as a positive member of FTE.vjsimone is gaining momentum as a positive member of FTE.
Do your pumps run with the OBD test connector is jumped ? pins 2 & 6.......
Old 05-20-2018, 12:31 AM
krooser's Avatar
krooser
krooser is offline
Ill try that Sunday....
Old 05-20-2018, 12:34 AM
Nikki Hampson
Nikki Hampson is offline
Nikki Hampson is starting off with a positive reputation.
Funny u mention fuel problems....
I ran a toggel for my fuel pump as well took 3 weeks and a lot of money before i ran the toggle.... Its been almost a year now and its still working lol any ideas on were to look for the power problem would be helpfull.... i have power at the silinoide but no further hence the toggle.... and if there is any way to get the fuel gauge to work ...... any replies are welcome good or bad thank you for reading...
Old 05-20-2018, 01:58 AM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Nikki , I recommend you start your own thread for your issue.
Old 05-20-2018, 09:10 PM
krooser's Avatar
krooser
krooser is offline
Well still no power to the fuel pump. I bumped up another thread from a guy having the same problem that was resolved by replacing the PCM. Might have to pull that out to take a peek. Won't be able to get to it until next weekend... my two days per week PT schedule will be 14 hours per day this week everyday... no time for monkey business!!!
Old 05-20-2018, 09:17 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
So, you did this;?
"Do your pumps run with the OBD test connector is jumped ? pins 2 & 6......."
and your pumps did not run?
Old 05-20-2018, 09:21 PM
krooser's Avatar
krooser
krooser is offline
So, you did this;?
Did not run...
Old 05-20-2018, 09:29 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Did not run...
if that didn't work (providing you selected the correct connections) then your EECM/Computer is not the problem.
you should check for power at the Fuel Relay Socket, there is a red wire there that should have batt voltage 12v+/-, with the key on.
Also, check the Yellow wire at the Fuel Relay Socket, with the key on, you should have batt Voltage there as well.
Old 05-20-2018, 09:42 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Connector plug;
Pin 2 - SIG-RTN
Pin 6 - Fuel Pump
Old 05-20-2018, 09:49 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Are you familiar with the Inertia Switch above the brake pedal ?
Old 05-20-2018, 10:16 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Did you hear your FPRelay clicking when you connected/disconnected Pins 6 & 2 on the test connector ?
Quick Reply: Temporary fuel pump power wire
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
