1949 F1 AOD swap
Old 05-18-2018, 05:41 PM
way2rod
way2rod is offline
way2rod is gaining momentum as a positive member of FTE.way2rod is gaining momentum as a positive member of FTE.
1949 F1 AOD swap
Hi Everyone,
I searched previous but couldnít find the info I needed so I experimented a little and would like to share what I found. Iím putting an AOD into my truck a 1949 Ford and needed a front yoke that would work for my existing driveshaft that I will be shortening. I found a 1986 Mustang GT (donít know if different) front yoke fits the stock front u-joint same exact size saves a lot of work finding the correct ujoint and then remembering what it was when need a new one. This way it will always be the stock ujoint. Hereís a few pictures.
Zac
Old 05-23-2018, 12:52 PM
gogoat's Avatar
gogoat
gogoat is offline
gogoat is starting off with a positive reputation.
yoke
Did the same, but used front one from AOD. Try these numbers
Yoke was .475 diameter
NAPA u joints 354C, 353
Good luck
jeffinct
05-07-2018 09:17 AM
BKruger
09-27-2004 05:11 PM
dug19
08-18-2004 07:15 AM
Col Flashman
08-06-2004 04:34 AM
Capone
1978 - 1996 Big Bronco
09-23-2003 08:26 AM
Quick Reply: 1949 F1 AOD swap
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
