302 ticking sound
302 ticking sound
I've transplanted an '82 302 from a Lincoln Towncar in my '77 F150. I just replaced the cam and lifters with an Edelbrock 2122 set due to what I thought was a lifter tick. Well, the new one makes the same noise. I've replaced the exhaust manifold gaskets as well, checked for leaks, none.
With the passenger side valve cover off, the tick is coming from the #4 cylinder exhaust valve from what it sounds. I have great oil flow from every push rod and rocker arms are all tight. The tick varies with rpms too. The rocker arms are not adjustable, anybody have any ideas?
I'll try to upload a video this afternoon.
Well the motor I chose to replace a 300-I6 that wouldn't maintain a good seal between the head and intake and exhaust manifolds wasn't really what I was looking to debate.
I have no indications of a head gasket leak in my oil, coolant, or compression tests, but thanks for the input on that.
feedbag_rides_again
13
03-21-2011 07:47 PM
debestuss
03-13-2004 01:17 PM
tetraruby
04-27-2001 11:22 PM
