Crank shaft positioning sensor part obsolete help?
Hey all,
I could use some help. I’ve been combing the internet for over a month and can not find this part anywhere. I have a ‘96 Winnebago and it has a E350 7.5L V8 motorhome and a bad sensor/check engine light on. It’s starting up and running but I really need to replace this part.
Part # F6TZ6C365LA
Please help/any suggestions???
This thing is literally nowhere. My motorhome only has 55K mikes on it and in great shape but some animal made a nest inside engine compartment and ruined a few things. All is fixed but this one damn part!
Part # F6TZ6C365LA
FORD #F6TZ6C365LA
Standard Motor Products # PC324
BWD #CSS720
ECHLIN #CSS436
CARQUEST #716786
WELLS #SU2036
FORD #2U2Z6C365AA
BECK/A #180-0427
http://www.kakapart.com/oem/partscro...tz6c365la.html
BWD #CSS720
ECHLIN #CSS436
CARQUEST #716786
WELLS #SU2036
FORD #2U2Z6C365AA
BECK/A #180-0427
Standard PC324 Engine Crankshaft Position Sensor
https://www.ebay.com/itm/Standard-PC...0AAOSwdVFawri~
These two are direct interchange parts. the rest were listed as indirect cross interchange. that is why i put the link at the bottom of the list of part numbers.
FORD #F6TZ6C365LA
The Ebay link is the correct direct interchange. One of the others I looked up had only 1 mounting hole.
What are people going to do when they cant find this part any more? 22 year old car and no parts?
This after market Chinese one is only $3.80 If you order 10,000 of them!
https://www.alibaba.com/product-deta...346416467.html
FORD #F6TZ6C365LA
I’ve now ordered 2 from different sources. One I found, the other from the link Clubwagon provided. Fingers crossed.
I have been on this search for over a month. I cannot believe this, we just sank over 3K into this motorhome and possibly for nothing because we can’t find this cheap part??? Very frustrating. Praying one of these things work. If one does, I’ll update this pist with the link to whatever worked if one does.
