Looking to swap NP 435 out for toploader.
Just wondering if the toploader 4 speeds would bolt up to my bell housing on the back of my 390fe in my 1968 f250. Don't worry the NP will be used in another project I have but my f250 is my daily driver and I would like to be able to use all 4 gears as I drive town alot and don't really tow or carry heavy stuff with her anymore.
on
Realistically, WHY? It won't save you any gas as it has a 1.1 along with the NP-435. Unless you drive around in 1st a lot.
NP_435 ratios NP435E (Ford)6.68 3.34 1.74 1.00 8.26
oploader 4 speed - Close1st2nd3rd4thRatio 2.32 1.69 1.29 1.00 Tooth Count32282523Counter Gear Tooth Count15182125
Toploader 4 speed - Wide1st2nd3rd4thRatio 2.78 1.93 1.36 1.00 Tooth Count32312523Counter Gear Tooth Count15212430
Best for the time and money is a 5 speed OD using a NVG 4500, or a cheaper alternative is using an FE adapter from Berndtsen's with a SBF ZF-5.
2x on a TKO... no adapter needed if ya spec a short shaft from Modern Driveline. Then it's a bolt-on. Super easy.
I did this swap thinking the toploader would be strong enough and OD would save me some fuel. Turns out it didn't save me any fuel and the toploader isn't anywhere strong enough. Swapped the NP435 back in. A ZF5/6 would be strong enough but require custom driveshafts and relocation of the cross member.
Whats the opinion on towing with a toploader? Obviously back in the day they did it. For an inexpensive transmission swap, what 5 speed is preferred. Im not looking for a clunky nv4500 to shift either. Would a mustang t-5 hold up to a 350hp 302? Can I tow 4500 pounds and not worry about breaking it? What TKO do people run?
Thanks
Thanks
A toploader would survive. I've drag raced mine for 30 yrs in a '69 F100 with 428CJ. They are a very stout transmission. I used to tow my 4600# wagon on a #1200 trailer behind my '70 F100 with 302/toploader. No problem.
I would NOT use a T5, especially if you thought to use OD while towing. It would not survive. OD is a very weak set up in those boxes.
Thats kind of what I was thinking, Freightrain. I would rather throw a $1000 toploader in, than a $3000 TKO. That extra money is whats going to pay for heads/cam/intake/exhaust. Im setting this truck up to be a nice daily driver that I can pull a car trailer/car on if need be. Eventually i might go to a 5 speed, or if the toploader works out, I would find a GV unit for OD and put a steeper rear gear in for a little better driveability.
Freightrain, whats your opinion on the 302 vs 351. Do you think it would be worth it in the long run to go 351? Im not looking for crazy power, but would rather have greater mpg. HP goal is around 350ish.
More CI is always better. My lil 302 drug my race car around for a few years til I upgraded to F350. Wasn't the fastest thing around, but got me there. It did have 4.10 gears. Back in the 90's, gas was still under a buck so mileage wasn't such a concern back then. If you have the 302, get a 347 crank kit for it? Those cheap stroker kits will work fine for you. Only when you start turning them over 6K do they start to split the stock 302 blocks. Even one for 351 can get you 390+ CI. All depends on what you want.
Sadly, I used to buy toploaders for $100 all day. Today they are $1000 with a paint job rebuild. Ugh.
Thanks
Thanks
I wish i had the money! Currently the plan is to leave the rear gears, as is for mileage optimization with a 1:1 final gear. Eventually I'll do an overdrive and some steeper rear gears. Is there another transmission that could be had cheap that would hold up for a little while? Something i could do some light towing with if need be? Im not to terribly interested in doing an NV4500.
Have you done this before? I’m guessing not because the truck FE bellhousing is deeper than the car one and you need the small block input shaft the have it engage the pilot bearing.
