Recently rebuilt engine need help locating where a few things connect. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 05-17-2018, 03:41 AM
CMcBreezy
CMcBreezy is offline
CMcBreezy is starting off with a positive reputation.
Question Recently rebuilt engine need help locating where a few things connect.
I have a 1988 Ford Bronco with a 302 in it and recently just rebuilt the engine. I almost have it all together but am having a hard time locating where what seems to be a vacuum tube coming out of the purge tank connects to, as well as one of the wire connections. Any help would be greatly appreciated!
Have no idea where this cord goes. It is connected to the purge tank and looks like it just needs a vacuum, but I am not sure where it connects to.
This wire is at the top of the engine and has a negative wire connected to it and cant seem to find where it connects to.
Old 05-18-2018, 07:17 PM
EllieMae94's Avatar
EllieMae94
EllieMae94 is offline
EllieMae94 is starting off with a positive reputation.
The first picture goes to the vapor canister purge valve, located on the square bracket right by the throttle body.
Old 05-19-2018, 06:02 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
vjsimone is gaining momentum as a positive member of FTE.vjsimone is gaining momentum as a positive member of FTE.
What are the colors of the wires to the connector ?
Old 05-20-2018, 07:12 PM
CMcBreezy
One of the wires is Green with two Black stripes, and the other wire is black with two white stripes.
Old 05-20-2018, 07:14 PM
CMcBreezy
Old 05-20-2018, 07:19 PM
CMcBreezy
The vapor canister there but the check valve isn't on there. I just ran it straight to the vacuum tree, will that work?
Old 05-20-2018, 07:32 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
I believe that is for your knock sensor.
And there is probably a stud near by for that ground lug.
there is usually a stud at the rear of the intake manifold, twards the drivers side.
This Orange wire lug is a ground for the ECA.... very important ground. This ECA computer has at the least 3 grounds, on of them connects to the battery, that one is important as well.
Old 05-20-2018, 10:35 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
You may have 2 small ports under your Throttle Body, these are for the lines to your Charcoal Canister, those 2 "Y" together into one line going to the Canister. Some have 2 ports on the Canister, then 2 lines would go from the Canister to the Thottle Body ports.
Probably not a good idea to run a line from the Canister to the vacuum tree.
The Canister vent hoses are not actually vacuum lines.
Is your vacuum diagram still visable under the hood somewhere ?
Old 05-20-2018, 10:55 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
You can see the two ports on this Trottle Body, bottom of photo.
Old 05-20-2018, 10:59 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
I don't believe the 5.0L had a Canister Purge Solenoid, just the 5.8L & 7.5L.
Old 05-20-2018, 11:05 PM
EllieMae94's Avatar
EllieMae94
I agree, I wouldn't hook it up to the vacuum tree. My '94 5.0 had the solenoid, perhaps not all years had one.
Old 05-20-2018, 11:46 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
The 5.0L used them from 1991 on. The 90, 89, 88, 87, 86, & 85 EFI 5.0L did not.
Old 05-28-2018, 09:59 PM
CMcBreezy
Thanks everyone for their replies, it's up and running correctly now! Locating that knock sensor was a bit of trouble since the location is in the back of the engine, but finally found it.
1986F150six
10-11-2014 01:41 PM
sr23
06-05-2014 09:23 PM
Bigjht
04-20-2007 05:00 PM
greenexplorer
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-03-2003 10:00 PM
jowilker
11-09-2002 09:50 PM
Quick Reply: Recently rebuilt engine need help locating where a few things connect.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
