New left over 6.7,Change Fuel filters at 1000 miles? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 05-16-2018, 09:34 PM
nico963's Avatar
nico963
nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
Im a new proud owner of a left over 17 6.7 and I could not be happier!!!!!
My question is,The Truck has a build date of 10/17 and I just bought it yesterday.With the truck sitting on the lot though the winter and though spring with Iím sure less than a quarter tank of fuel in it this whole time I imagine the fuel isnít in the best shape.Obvously the dealer filled it up for me and Iíve got around 300 miles on it.My plan was to put a few more tanks of fuel thought it and change the fuel filters around 1000 miles just Incase it grew some crap in the tank from the temp swings and sitting for months stagnant.
Over thinking?Or good idea?
Old 05-16-2018, 10:04 PM
Iowa Ford's Avatar
Iowa Ford
Iowa Ford is offline
Iowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputation
Waste of money, but it's up to you.
If the fuel is that bad that the filters are plugged in 1000 Mi, you have bigger problems.
I get that it's your new truck, but it will be fine.
Enjoy your new truck !!
Old 05-16-2018, 10:31 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.
+1 on the filters are fine. Pictures?
Bruce
Old 05-17-2018, 12:28 AM
bobv60
bobv60 is offline
bobv60 has a good reputation on FTE.bobv60 has a good reputation on FTE.
I would open the drain on the lower filter and see if there is any water.
Old 05-17-2018, 04:41 AM
JohnD333
JohnD333 is offline
JohnD333 has a good reputation on FTE.JohnD333 has a good reputation on FTE.JohnD333 has a good reputation on FTE.
X2, and do it every month like clockwork. If it is gunky fuel and water mix that comes out the first time I would not worry about it, but would drain again in 2 weeks. If just clear fuel and a bit of water, or clear fuel, this second time, all is ok and run for 15-20k miles depending upon how much you tow, draining a water test sample every month. If still a mix of gunk and fuel, change the filters but add some biocide first - see below.
I have had 3 of these with 100k miles and never experienced gunk come out of the drain, and only very rarely a few water droplets. But all it takes is once, thus every month a bit is drained off into a clear cup - actually a translucent plastic bowl. Ususlly, but not when i have not driven much, I back the drain plug out to a point where fuel comes out not just through the drain but also past the seal on the stem/****. Water is a killer.
6 month old bio-fuel can be a problem with alge growth. Not likely in cold weather or with little fuel in the tank. A single treatment with biocide should clean it up. I gunk comes out, i would add that, fill the tank and run for 100 miles before changing the filters.
Old 05-17-2018, 05:17 AM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
it should have had an oil change by the dealer though...filters, just drain and see. I'd change them at around 10K though.
Old 05-17-2018, 07:13 AM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
Way over thinking it. I bought a leftover 16 that sat on the lot for 11 months with a 1/4 tank of fuel in it, ran just fine during the test drive. Dropped the factory oil at 5k miles and changed the fuel filters at 12k miles, no problems whatsoever.
Old 05-17-2018, 07:27 AM
The Bone's Avatar
The Bone
The Bone is offline
The Bone has a good reputation on FTE.The Bone has a good reputation on FTE.
Enjoy the truck. Follow the manufacturers recommendations in the book and you will get many years of enjoyment from your truck
Old 05-17-2018, 08:13 AM
nico963's Avatar
nico963
nico963 is offline
Thank you so much,It makes me feel a bit better.Ill drain the fuel filter after this first tank and probably the second tank too and see what I get.I thought about having the dealer change the oil but talking to a few people it was thought it wasnít needed.I do get the first oil change free and the dealer said I can change it whenever I want.I might do it around 1500 miles just to start fresh again.
No pics yet as my computer is down and Iím doing everything on my phone and for some reason the fourm doesnít like my pics from the phone.Ill try and change the format later and try again.
Thanks again and I am absolutely loving the Truck!!!!
Old 05-17-2018, 11:22 AM
nuctrooper
nuctrooper is offline
nuctrooper has a good reputation on FTE.nuctrooper has a good reputation on FTE.
That's only 6 months - plenty of experience with much longer layup periods here on the boards.. Absolutely nothing to worry about for fuel or oil. Your choice of course how you want to spend your money, but there really isn't a "start fresh again". The truck IS fresh right now with only 300 miles on it. Enjoy it, change at the recommended interval.
Old 05-17-2018, 11:43 AM
nico963's Avatar
nico963
nico963 is offline
Thanks for the advice!
Old 05-17-2018, 09:05 PM
Troy Buenger's Avatar
Troy Buenger
Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
I agree with draining the fuel from the filter after your first tank of diesel. After that drain monthly and enjoy the ride.
My truck is going on 6 years and 145k miles and it runs like a top and it sat on a dealer lot for a little longer than yours. Did first oil change at 3,500 miles and fuel filters at 15k miles.
Old 05-18-2018, 06:52 AM
nico963's Avatar
nico963
nico963 is offline
Good to hear!Im not gonna worry to much about it.The Truck is an absolute dream.
Old 05-18-2018, 08:24 AM
The Bone's Avatar
The Bone
The Bone is offline
I just did my second fuel filter change and I have 52.000 miles on my truck. I see no issues with the main filter at all. I have fueled up at many different stations in many different states since the last filter change so I go about 26.000 miles on the filters. No dirt or water in the fuel as far as i could see. Filter was gray so it was doing its job. As for the oil i have a GT500 and only change the oil once a year. I don't drive it more than 1,500 miles a year. Your truck came with synthetic oil which makes all the difference. Personally I would continue that practice even though it's way more expensive around $200. I find synthetic is better for the gaskets and seals.
Old 05-18-2018, 09:09 PM
nico963's Avatar
nico963
nico963 is offline
I plan on synthetic for sure.I used it in my 6.0ís and they loved it.
MustangMatt96GT
09-12-2010 07:13 PM
Storm
01-09-2007 08:53 AM
Hotwheelbill
04-19-2006 07:01 PM
Navistation
13
08-23-2005 06:56 PM
Teedo47
09-20-2004 01:41 PM
Quick Reply: New left over 6.7,Change Fuel filters at 1000 miles?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
