E4TA-7500-DA Confusion
At Gary’s Garage the bellhousing part numbers link (Bell Housings - ???Gary's Garagemahal) shows the housing marked E4TA-7500-DA to be for 1984-1987 460 4 speed, but on eBay the listings for E4TA-7500-DA say they are for small block Ford & don’t look like my cracked one, e.g. https://www.ebay.com/itm/Ford-Small-...AAAOSwqHBa60xe
Confused!
Confused!
but on eBay the listings for E4TA-7500-DA say they are for small block Ford & don’t look like my cracked one.
You are adding words to the ebay ad, it says nothing inre to E4TA-7500-DA .. Ad plainly states E4TA-7505-DA.
e.g. https://www.ebay.com/itm/Ford-Small-Block-v8-Bell-Housing-F150-Truck-4-Speed-E4TA-7505-DA-Hydraulic/192529724017?hash=item2cd3aa7271:g:AiAAAOSwqHBa60x e
E4TZ-7505-B .. Bell Housing - Use with 460 & T-19 4 M/T / Marked: E4TA-7500-DA
E4TZ-7505-C .. Bell Housing - Use with 4.9L/5.0L/5.8L / Marked E4TA-7505-DA
Pic: Applications and ID engineering numbers for 7505 bell housings from Ford Truck Pass Catalog - Open your peepers and take a look-see.
You are confusing one ID engineering number with another. E4TA-7500-DA is NOT the same bell housing as E4TA-7505-DA
LilToe
07-04-2016 09:15 AM
ufvj217
05-19-2015 04:18 PM
92 Black Nite
1978 - 1996 Big Bronco
12-23-2012 10:44 AM
rockher_man
13
03-01-2009 01:41 PM
