Correct spark Plug for 2000 Expedition 4.6 4WD - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997-2006 Expedition & Navigator
Reload this Page >
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-16-2018, 06:48 PM
brimis
brimis is offline
brimis is starting off with a positive reputation.
I want to change the plugs in my truck because it's been awhile. I was given Motorcraft SP-432 spark plugs. The plug has a full set of threads.
The plug I removed is a Motorcraft AWSF 32P and this plug has literally half the amount of threads.
Was I given the correct plug? If so why the change in thread pattern. I haven't installed the plug as of yet. Would like to confirm I have the correct plug.
2000 Ford Expedition 4.6 4WD 117,000 miles.
Respectively,
Brimis
Old 05-16-2018, 08:20 PM
Hamfisted's Avatar
Hamfisted
Hamfisted is offline
Hamfisted is gaining momentum as a positive member of FTE.
The SP-432 set should be correct for your Expy ( gapped to .054 ). I don't know why the plugs don't look exactly like each other. Are all the plugs you're pulling out alike ? Are you the original owner ?
Old 05-16-2018, 09:09 PM
brimis
brimis is offline
That is the plug that was given to me from the auto shop. The plug that was in the truck has half the amount of threads. I'm the second owner, I bought the truck 14 years ago when it had 30,000 it now has 117,000.
Old 05-16-2018, 10:52 PM
lv2race's Avatar
lv2race
lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
The distance from the end of the plug to the chamfer (seat) will be the same. The older plugs didn't have threads all the way up to the chamfer. You're fine.
Old 05-17-2018, 10:00 AM
Hamfisted's Avatar
Hamfisted
Crap, I wasn't even thinking about what he was talking about. I thought he meant the whole threaded shaft was shorter LOL. Like a previous owner put short shafted plugs in it. This is another post where pictures would've really helped.
-Mike
Old 05-17-2018, 11:33 AM
lv2race's Avatar
lv2race
lv2race is offline
Like this?
Old 05-17-2018, 04:09 PM
brimis
brimis is offline
Originally Posted by lv2race View Post
Like this?
That's it. Thank you so much.
Respectively,
Brimis
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
