Anyone have the Ford Bed Divider?
Would like some details on that fancy accessory. For $295, I'm hoping it's more than just a heavy duty plastic barrier that secures to the bed mounting points.
And for an added bonus, I'm curious if it can be mounted upside down, with the barrier facing up?
I have the bed divider on my 015 that I traded a set of Ford rims for. The bed divider is a heavy duty barrier that mounts to side rail mount points. I went outside and looked at mine and I don't see how you can possibly turn it upside down or maybe I'm not understanding your question. I use it to bank small loads near the tail gate. Hope this helps
Yes it fits under a tonneau cover and no, you can't mount it upside down because of the way it locks into the mounting plates.
After I got mine I installed a couple of lengths of "Slide-N-Lock" tie down rails and locking pins. One length on either side of it. This allows me to ratchet strap or bungee items to either side of it. My only complaint is that since it attaches to the tie-down locking plates, there are only 2 possible locations in the bed for it.
