New core support from DC.
This is a new radiator support for a 1966 from DC. Looks different than mine. Has different radiator attachment configuration.Mine is flat. Hmm,what will I need? Make Model Body Style Notes Year
Ford Truck F100/250 2WD 1965-66
Ford Truck F100 4WD 1966
Notes
1966 2WD will need additional holes drilled
Or will it need to be reworked similar to below.
1966 Ford F100 Restoration: Using the reproduction core support
Notes
Carpenter says C6TZ-16138-C = 1965/66 F100/250 2WD & 1966 F100 4WD but there's NO such thing, as this was NOT used on 1966 F100/250 2WD
The following is correct:
C6TZ-16138-B = 1966 F100/250 2WD
C6TZ-16138-C = 1965 F100/250 2WD; 1966 F100 4WD
This wrong application support was discussed several months ago.
That SURE looks to me like a 65' core support. If I get a little time tomorrow, I will take some pics of both a 65' and a 66'. BUT, if indeed that is the 65', I would buy one just to keep one on hand just in case DC decides to stop making them. 65' is a 'one year' only. Unless that picture is an old DC pic and they are trying to say it will also fit a 66' - NOT...
This is a 64 core support from Carpenter that I modified for a 65. Your support looks like the same part that they added the inner fender brackets to. I don't know what a 66 should look like but I don't see the lower brackets for the inner fenders or weld nuts for the battery box on that support you got.
Murphy1966
06-07-2016 02:58 PM
66with352
04-13-2016 09:16 PM
