whats this piece Do is it broken? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-18-2018, 03:07 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
moose4x4 is starting off with a positive reputation.
Originally Posted by Xand17 View Post
i think its part #7A256, how does this part affect parking gear, would this piece also cause a hard shift into D or other gears?
One More Time!! The piece in you hand is the 7d261 with the S part inside the pan broke off the shaft!! If you take the piece in your hand and pull the nut off the arm, which is different than in the diagram, ( Number Dummy said this pic was from a CAR catalog. The lever 7a115 in diagram will NOT look like yours.)After you take nut and lever off of the one in your hand you will have only the shaft of 7D261 with the S lever broke off. The S lever is binding on the 7A115 which is the lever that shifts truck into gear and also park. The 7A115 is hooked to the 7A256 shaft that is on outside of transmission where the shift rod comes down from the steering column. You have to pull pan and pull the s lever out and truck should shift ok. But will still leak unless you repair the shaft7d261.
Old 05-18-2018, 03:35 PM
Xand17's Avatar
Xand17
Xand17 is offline
Xand17 is starting off with a positive reputation.
Thank you. That makes so much more sense. So I need a replacement for the s part inside? Can it go without?
Old 05-18-2018, 03:50 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Read post #13.
Old 05-18-2018, 04:58 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
Can it go without?
Short answer YES, but you have to seal the hole in 7A256 where it will not leak. gonna be hard to do. But you have to get the S piece out of the inside of the transmission to get linkage freed up???? Possibly???
See post #13
Old 05-18-2018, 06:06 PM
Xand17's Avatar
Xand17
Xand17 is offline
I have my mechanic working on this tomorrow. So if we wanted we could just place a bolt and nut with O-ring to seal the hole and go without the s part?.
Old 05-18-2018, 09:21 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
I have my mechanic working on this tomorrow. So if we wanted we could just place a bolt and nut with O-ring to seal the hole and go without the “s” part?.
Yes as long as the linkages inside the tranny are not messed up (bent) etc.
Old 06-04-2018, 01:59 PM
Xand17's Avatar
Xand17
Xand17 is offline
Part number hell
Will this work?
Other Part Number
FC6-74A
Manufacturer Part Number
D0AZ-7D261B
Transmission Throttle Lever / Kickdown Lever its feom a 1970 C6 tramsimmion
Old 06-04-2018, 07:48 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
Will this work?
Other Part Number
FC6-74A
D0AZ-7D261B
Should do just fine, be sure to put a new oring/seal in or it will leak and you'll have to pull pan again.
tastyklair
09-02-2004 11:04 PM
threefiftyone
08-30-2004 05:27 PM
MDK
06-19-2004 12:59 AM
Polkat
05-18-2003 08:57 AM
Mr Man
04-18-2002 07:07 PM
Quick Reply: whats this piece Do is it broken?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
