2008 F350 6.4 Diesel EGR delete chipped. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 05-16-2018, 02:37 PM
Mulsanne
Mulsanne is online now
Mulsanne is starting off with a positive reputation.
Driving on a hot day and cruising around 70mph, the coolant temp gauge goes to hot and reduced power message is displayed. If I sit off road in park, with the motor running the gauge returns fairly quickly (you can see the needle fall) to normal and the trunk drives well again. The engine temperature does not appear hot nor has it puked out any coolant. I changed the thermostats with no change. The coolant level is correct and the fan is turning.
Can anyone help?
Thank you, Martyn
Old 05-16-2018, 05:02 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is online now
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
Possibly bad thermostats. Seems like I have read about them over extending I think. Which can cause over heating issues. Just a thought.
Old 05-16-2018, 05:09 PM
Mulsanne
Can anyone help?
Thank you, Martyn
As a footnote to the above, I took the truck on a road test with a SnapOn scanner plugged in. When the fault occurred, the readings for the water temp were 197 and didn't move and the oil temp was 259 and steady. There were no codes stored, nor did it show a code with the fault.
Martyn
Old 05-16-2018, 08:26 PM
JoshC017's Avatar
JoshC017
JoshC017 is online now
JoshC017 is starting off with a positive reputation.
Your oil cooler is plugged up. At 259* on the oil, you're waaaaaaay out of spec. Anything about 20* above coolant temp is bad. You need to get that looked at asap.
Old 05-17-2018, 09:11 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
and what are the codes that were pulled from the odbc port?
Old 05-17-2018, 09:39 AM
Mulsanne
Thanks Speakerfritz and JoshCO17
There were no codes for some reason and I have taken the truck in to get the oil cooler sorted. I had previously changed the thermostats thinking that it was the coolant temp that was causing the issue. I didn't realize that the oil temp triggered the gauge on the dash.
Thanks Guys for your input and will keep you posted as to the results.
Martyn
Old 05-19-2018, 05:11 PM
JoshC017's Avatar
JoshC017
I had a 6.0 that I just got rid of that did the same thing last summer. Cruising along pulling the camper and boom, all the sudden the dash starts beeping at me and the coolant temp gauge goes from normal to max in an instant. Later discovered that it was my oil cooler. Good luck with the fix. Report back when you get some good numbers.
Old Today, 11:12 AM
Mulsanne
Thanks Guys
I'll report back with the news.
Martyn
beemr
09-06-2017 01:40 AM
Antiquer88
09-01-2016 10:23 PM
joegeds
08-11-2016 08:44 AM
mark460
06-30-2016 01:33 PM
cmh15
1968-2013 Full Size Vans
06-12-2016 12:11 PM
Quick Reply: 2008 F350 6.4 Diesel EGR delete chipped.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
