Installed X codes now to bring the rear up 2" or so - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Reload this Page >
Old 05-16-2018, 09:23 AM
ToysRUs's Avatar
ToysRUs
ToysRUs is offline
ToysRUs is gaining momentum as a positive member of FTE.ToysRUs is gaining momentum as a positive member of FTE.
It's been a long time since I have been on here and finally after a few years I have time to devote to my Ex.
So I had my stepson/Infinity mechanic install X codes from SDtruck springs along with Bilstein 5100's
I am loving the ride up front. Since I don't tow a camper anymore I am actually fine with the capacity and the ride in the rear.
I just need to bring the rear end up and level then add Bilsteins.
I've browsed around the threads but haven't found an easy way to do this. Either install Modded B codes,(more work than I really want to do based on my free time) Or change to 2" taller blocks (which goes against my powersports suspension background but maybe....) But maybe install a RAS kit?????
I looked at the RAS kit when I first got this truck but the weight dist bars worked just fine for my then toyhauler. I'm wondering if I cna get almost 2" of lift with them....Fairly cheap and easy to install.
What are your thoughts?
Old 05-16-2018, 11:26 AM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
Shade Tree Wrencher
SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.
NEW longer U bolts, replace the rear 2 1/2” blocks with 4 1/2” blocks. These are very nice.
Ford F-250/350 Fabricated Lift Blocks
Old 05-16-2018, 11:37 AM
jasoncw's Avatar
jasoncw
jasoncw is offline
jasoncw has a very good reputation on FTE.jasoncw has a very good reputation on FTE.jasoncw has a very good reputation on FTE.
You might get an inch out of the RAS, but not 2".
Old 05-16-2018, 11:21 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is online now
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
If a block goes against your better judgment then a RAS should definetly be crossed off your list.
it is just a fancy add a leaf in the form of a coill spring, it, adds spring rate but no additional travel.
your best bet is to order a 2” taller spring with the factor spring rate of 420 pounds per inch.
I have never purchased from ATS but people rave about the service Junior provides.
Old 05-17-2018, 05:52 AM
SmackDaddy's Avatar
SmackDaddy
Shade Tree Wrencher
Superdutys come with a rear block from the factory, what’s wrong with removing them and adding a taller block? You will pay a lot more for a full spring than just a set of blocks.
Old 05-22-2018, 09:01 PM
ToysRUs's Avatar
ToysRUs
ToysRUs is offline
So I went ahead and decided to install ReadyLifts 4" block set. Took out the 2" block and installed the 4" block. Now it is level.
Yes, it still goes against my suspension building experience but it is a street truck mostly. If it was a desert truck it would be different.
In the end I am happy with it.
Added DEDC new style towing mirrors also...They are nice..
Tylus
06-30-2013 01:53 PM
2000gpr
1997-2006 Expedition & Navigator
01-20-2008 05:28 PM
atillett
10-22-2007 09:24 PM
Metro-Nut
11-18-2004 12:01 PM
Quick Reply: Installed X codes now to bring the rear up 2" or so
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
