front driveshaft turning in 2wd - Ford Truck Enthusiasts Forums
Old 05-16-2018, 08:06 AM
ithaca1230's Avatar
ithaca1230
ithaca1230 is offline
ithaca1230 has a very good reputation on FTE.ithaca1230 has a very good reputation on FTE.ithaca1230 has a very good reputation on FTE.ithaca1230 has a very good reputation on FTE.
I'm chasing a squeak that is not always there. dropped it off with mechanic and they told me the u joint on the front shaft looks rusty and that the front shaft is spinning even though it is 2wd. Am I correct that is should only spinn in 4wd and not in 2wd.
Thanks Billy
Old 05-16-2018, 09:10 AM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is online now
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
Correct,
if the drive shaft is turning when the transfer case is in 2wd then you have a locked or sticking hub.
typically results in the axle seal wearing out also so be sure to check that.
Old 05-16-2018, 11:37 AM
ithaca1230's Avatar
ithaca1230
Originally Posted by pirate4x4_camo View Post
Correct,
OK thanks I put new hubs in last year so I hope its not that.
Old 05-16-2018, 12:58 PM
EXSwap's Avatar
EXSwap
EXSwap is online now
EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.EXSwap has a great reputation on FTE.
I had the same issue. Turned out to be too much grease in my locking hub combined with the cold wouldn't let it unlock. They're easy to pull out and if you do, you should be able to spin the front shaft freely by hand. That'll at least tell you which side it is if you pull one at a time and check them.
Unfortunately, I also have the same intermittent squeak in the front shaft. Best I can tell it's at the insertion point into the transfer case. It's been added to the loooong list.
Old 05-16-2018, 02:01 PM
wpnaes's Avatar
wpnaes
wpnaes is online now
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Good time to recall Brentís tranny-soaked rag application (note I didnít say fix ).
Old 05-16-2018, 03:20 PM
ithaca1230's Avatar
ithaca1230
Well a few things going on. Driver side hub was not dissenting. Vacuum was not working correctly only one of the two was coming out of the switch was working. New warn hubs all taken care of. Squeek is only when hubs are locked in. The best they can figure is that it is the vacuum seal. I was there spinning the bearing while mechanic was probing with a stethoscope. We decided to leave it as is since it only makes noise when hubs are engaged and something I can do on my own. No more auto hubs oh well tired of messing with them.
Old 05-16-2018, 06:44 PM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
Shade Tree Wrencher
SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.SmackDaddy has a very good reputation on FTE.
I did the same thing recently. Screw that ESOF system!
Old 05-16-2018, 07:49 PM
pirate4x4_camo
Now we just need somebody to make a manual shift mechanism to replace the electric motor setup.
Old 05-18-2018, 07:51 AM
ithaca1230's Avatar
ithaca1230
So now that we got the manual hubs in and squeaking only occurs when hubs are locked or 4wd is engaged. I guess I will have to order a new vacuum seal and replace it. They are aprox 1.5 year old maybe 10,000 miles on them. I replaced both and the bearings.
Old 05-18-2018, 07:56 AM
SmackDaddy's Avatar
SmackDaddy
Shade Tree Wrencher
I have a new set of Motorcraft hub rebuild kits for sale in the classifieds. I went to manual Warn hubs so no need for them. Brand new not opened.
Old 05-18-2018, 10:34 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
C'mon, don't knock it till you've tried it!
I mean, it is linked in the tech folder after all, so that has to mean something, right?
Stewart
Old 05-18-2018, 12:17 PM
ithaca1230's Avatar
ithaca1230
Stewart
I will look at that again.
Thanks
Old 05-18-2018, 02:22 PM
wpnaes's Avatar
wpnaes
Good one Stewart!
Bill Payne
1999 to 2016 Super Duty
12-23-2013 01:55 PM
cbzdel
04-08-2012 12:59 AM
PJMar
1997-2006 Expedition & Navigator
05-12-2010 02:27 PM
BSHORT
06-23-2004 05:26 PM
GB
13
11-03-2002 08:07 PM
Quick Reply: front driveshaft turning in 2wd
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
