97 F250H.D. 5.8l No Acceleration after 35mph.
Old 05-15-2018, 05:36 PM
Kellarjr90's Avatar
Kellarjr90
Kellarjr90 is offline
I just inherited a 97 F250H.D. 5.8l from my grandfather. The slave cylinder was out in the truck when I got it. I replaced it myself. After I got the truck rolling again, I noticed it didn't have a lot of power in town, so I got up on the highway to test it out. It drives fine up to 35mph, after that it seems to lose all power. It is OBD1, I ran the codes, and it threw 12 different ones. I've replaced everything that the codes showed to be bad. Now, it idles better and has more power in low range, and I can get it up to 65mph. It takes almost 4 miles on the highway to get to this speed though. So, I have only been using it to put around town doing things. My check engine light came back on today, and when I ran the codes I got (K.O.E.O) 111, and (K.O.E.R) only threw a 4. I wiped the memory, and drove it until the light came back on, after about 5 minutes of driving, and it says the same thing. I can not figure out what is wrong with the truck, and I would like to get it back up and running in memory of my grandpa. So, any help would be greatly appreciated. I would like to do all of the work myself, so if anyone has any ideas they would be greatly appreciated. Thank You.
Old 05-23-2018, 02:48 AM
roboto65's Avatar
roboto65
roboto65 is offline
Back to basics have you done a compression check with the engine warmed up what were the readings if you did. Have you checked the timing should be around 10 BTDC. Tune up have you replaced Cap,rotor,spark plugs and wires?
Blackangel915
04-26-2017 01:45 PM
onesr
04-18-2012 10:55 PM
Moore FOMOCO
Modular V8 (4.6L, 5.4L)
13
05-18-2006 07:42 PM
joners
12-03-2005 12:35 AM
Quick Reply: 97 F250H.D. 5.8l No Acceleration after 35mph.
