new headers now bronco wont run right - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 05-14-2018, 11:39 PM
Holmgrown
Holmgrown is offline
Holmgrown is starting off with a positive reputation.
I have a 1993 Bronco with 5.0l 302w auto trans
hey everyone,
I am new to the site and cant seem to find anything to assist me with my problems. I installed some new shortie headers on my rig, and now it doesn't want to run right. it is stalling out at idle and sometimes when I am stopped at a stop light. while trying to fix my problem I have installed new iac valve, map sensor, spark plugs/wires, distributor cap and rotor.
Is there a possible loss in backpressure that will not allow my engine to run properly or what?
Any and all advice would be greatly appreciated,
thank you.
Old 05-15-2018, 12:42 AM
75BigBlock's Avatar
75BigBlock
75BigBlock is online now
75BigBlock is starting off with a positive reputation.
Is that all you initially did was install headers? Did you unhook anything off the old manifolds that you didn't reinstall with the headers? Like... an O2 sensor or something?
Old 05-15-2018, 12:52 AM
Holmgrown
nope, I put everything back where itís supposed to go. The only o2 sensor I can find is down by the cat on the y-pipe
Old 05-15-2018, 01:06 AM
75BigBlock's Avatar
75BigBlock
Other than accidentally unplugging something as you were installing things I'm not sure what it could be, sorry. I haven't dealt with many "newer" vehicles or should I say attempted to fix newer ones. I would just double triple check every wire and connection. Sometimes things give out at the most inconvenient of times.
Old 05-15-2018, 01:08 AM
Holmgrown
Thank you I appreciate it
Old 05-15-2018, 01:03 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
double check your firing order. I did this very thing and had a wire or two swapped. also make sure you dont have any of the wires touching the headers, they will melt and cause a loss in spark.
Old 05-20-2018, 10:36 AM
Bruners4's Avatar
Bruners4
Bruners4 is offline
Bruners4 is gaining momentum as a positive member of FTE.
Also double check the vacuum lines. Those hard plastic lines break very easily.
masonandeers
19
01-05-2016 04:25 PM
sandrat88
31
08-24-2012 01:38 PM
300/6 Freak
03-25-2010 03:25 AM
shanksyamaha
Modular V10 (6.8l)
07-30-2009 02:51 PM
jrezba
15
12-20-2005 03:59 PM
Quick Reply: new headers now bronco wont run right
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
