1966 Fuel Filler Hole Cover
Old 05-14-2018, 11:28 AM
Stormin926
Stormin926 is offline
Stormin926 is starting off with a positive reputation.
Does anyone make a fuel filler hole weld-in cover for the '66? I'm relocating the gas tank. Someone found this MAC part number 48-29108-1, but it's for the F1. I can get an old cab fuel fill area cutout of a commercial vehicle that doesn't have the fill in the cab from FlashbackF100s.com and weld it in. I was hoping for an easier and better way than replacing all that sheet metal.
Again, any help is greatly appreciated!
Old 05-14-2018, 01:09 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
A phone call ould verify if they are the same diameter. But don’t you think it would be coolest to just insert a beer can or your choice?
Old 05-14-2018, 04:18 PM
James_Western_Canada
James_Western_Canada is online now
James_Western_Canada is gaining momentum as a positive member of FTE.
Get a piece of sheetmetal of the correct gage, shape it to the required contour (you cab do this by lightly tapping the piece over a hollow (eg: an "offcut" piece of 3" or 4" pipe)
Trim any flange, or recess off the original opening in the cab corner, then fit your patch piece flush, and buttweld it in place.....
As far as a patch piece from a heavy truck cab, they generally had the hole for an in-cab tank, just like the lighter trucks, which was filled with a large "Blind Grommet"
Old 05-15-2018, 06:44 AM
Stormin926
Thanks James for the photos and the fabrication comments. I was hoping not to have to shape too much metal, but I will try my hand at shaping that piece. I would rather not cut the cab upper corner out anyway.
Thanks also for the information on the heavy truck cab. If I go that route, I'll have to request a photo prior to purchasing the section at the filler area just to make sure I'm not getting the same thing that I have now.
Old 05-15-2018, 08:02 AM
emeraldcoupe's Avatar
emeraldcoupe
emeraldcoupe is offline
emeraldcoupe has a good reputation on FTE.emeraldcoupe has a good reputation on FTE.
Old 05-15-2018, 09:02 AM
Stormin926
Excellent! Thanks for the LMC link! $12!
Keymaster
29
01-16-2018 10:52 PM
68shortbedmo
08-04-2017 05:53 PM
390puller
06-10-2017 01:21 PM
kaw500h1
28
01-07-2017 02:33 PM
Shark Racer
08-02-2010 12:41 PM
Quick Reply: 1966 Fuel Filler Hole Cover
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
