2015 F350 diesel strange noise. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 05-12-2018, 10:43 PM
vinceherman's Avatar
vinceherman
vinceherman is offline
vinceherman is starting off with a positive reputation.
33k miles, some pulling the fifth wheel but mostly commuter miles.
This spring we noticed the engine making an unexpected noise. A roar from under the hood when we are used to the deep diesel grunt. It follows the engine RPM rather than road speed, and gets louder at higher RPM (2000 or so)
Tonight I popped the hood and had my brother tach it up to 2200. There is a loud roar from the radiator area, likely the fan.
Do you think it is the radiator fan blades making all that noise?
Is the fan clutched to not run except when it is needed to pull out heat from the coolant?
Does that clutch ever fail ‘locked up’ so that the fan turns full speed all the time?
Old 05-13-2018, 03:41 PM
jpennell1
jpennell1 is offline
jpennell1 is starting off with a positive reputation.
Its possible to fail and be on all the time, but very unlikely. When the fan clutch fully engages, I.E. during a manual regen, these engines sound like freight trains. Probably normal. Try it one morning cold, with no A/C on.
Old 05-13-2018, 06:09 PM
jav_eee
jav_eee is offline
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
It's probably your fan clutch engaging and yes it's normal. Unless you're hearing it all the time. If that's the case then you might have a problem somewhere.
Old 05-13-2018, 09:44 PM
vinceherman
I do hear the roar all the time that the engine RM is above 1800 or so. This includes first thing in the morning, if I apply a bit of throttle accelerating down the road.
Any time that the RPM is close to 2000. It is the same roar that I heard from the fan area with the hood open. That was with the engine warm. I will try it again tomorrow morning with everything cold.
At full highway speed, you can hear it over the rest of the engine and road noise.
Old 05-14-2018, 08:24 AM
The Bone's Avatar
The Bone
The Bone is offline
The Bone has a good reputation on FTE.The Bone has a good reputation on FTE.
Grab the fan with the engine off of coarse.If you can move the fan around than the clutch isn't locked up however there should be some resistance but it should move easy and smooth. You shouldn't be able to spin it.
Old 05-14-2018, 08:52 AM
Tom's Avatar
Tom
Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Moved to the 6.7L forum.
Old 05-14-2018, 10:32 AM
vinceherman
I will give that a go. But the fan is pretty well buried with the shroud hiding most access.
Old 05-14-2018, 04:43 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
As I understand it, the fan on the diesel is controlled by the computer. In other words it's not an independent entity. The fan on my old truck was NOT controlled by the computer. If the engine was hot, even when turned off, then the fan would be locked up and very stiff to turn by hand.
My question then is, if the engine is OFF will the computer release the fan even though the engine is hot? The answer to that may invalidate the "try to turn the fan when the engine is off" test.
Old 05-14-2018, 10:57 PM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
Forscan be able to see fan on or off signal?
Old 06-04-2018, 07:47 AM
Bill_The_PA's Avatar
Bill_The_PA
Bill_The_PA is offline
Bill_The_PA has a good reputation on FTE.Bill_The_PA has a good reputation on FTE.Bill_The_PA has a good reputation on FTE.
Does that clutch ever fail Ďlocked upí so that the fan turns full speed all the time?
OP you ever get this resolved. Iím having the exact same issue as you discussed.
Quick response would be great....did this end up being Normal.
Old 06-04-2018, 08:31 AM
vinceherman
No, I did not take it in. I was able to turn the fan by hand with the engine off. There was resistance but not locked.
I am assuming that if the fan is turning harder that it should, nothing catastrophic is going to happen. A little less fuel economy?
If you find out anything, please report back here.
Old 06-04-2018, 09:11 AM
Bill_The_PA
No, I did not take it in. I was able tuo turn the fan by hand with the engine off. There was resistance but not locked.
I just dropped it off. Iíll keep you informed
Old 06-22-2018, 09:27 AM
vinceherman
Bill, did the shop say anything helpful about this issue?
Old 06-22-2018, 02:56 PM
99150's Avatar
99150
99150 is online now
99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation
Hey guys.......is your A/C turned on? If so, at low ground speed or parked your cooling fan should kick in to pull air across the condenser coil.
Old 06-22-2018, 03:02 PM
vinceherman
I had confirmed that the AC and defroster were off. The noise of a roaring cooling fan at full speed is still there.
Quick Reply: 2015 F350 diesel strange noise.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
