Would you run 18 year old oil? - Page 2 - Ford Truck Enthusiasts Forums
Old 05-13-2018, 01:12 PM
hydro man 17
hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
One question. Is the date on the bucket bottom molded in to the bucket or is it a sticker? If it is "in" the bucket it could have sat empty for some time before it was ever used.
Old 05-13-2018, 01:42 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
It was a code bar sticker with some numbers and the date, I do believe its 18 year old oil i mean Ive been working in that company for more than 11 years and have seen those buckets stored there since i started working there. I order the sample last night when ever I get the results back ill post them up.
Old 05-14-2018, 01:10 AM
'88 E-350
'88 E-350 is offline
'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.
I'll bet it's junk. I would use it as fuel, but not motor oil. I'll be shocked if the test comes back good. I've seen oil only a year or so old have sediment at the bottom of the bottle, the sediment is supposedly good stuff that has separated out. I always wondered if the sediment might be 'junk' in the oil. I'll bet the bottom of that bucket has a nice dark layer of stuff, give it a check.
Old 05-14-2018, 08:54 AM
z31freakify
There was a small amount of lard looking stuff at the bottom but it was almost nothing, the size of a quarter. I did take out the oil and put in in some 2.5 gallon containers as the bucket got brittle.
Old 05-14-2018, 02:22 PM
empiretc's Avatar
empiretc
empiretc is offline
empiretc is a splendid one to beholdempiretc is a splendid one to beholdempiretc is a splendid one to beholdempiretc is a splendid one to beholdempiretc is a splendid one to beholdempiretc is a splendid one to behold
Originally Posted by z31freakify View Post
Ill order a Test kit on Monday and send it out ASAP im just curios as to what Blackstone scientist will say.
Yes, please let us know what they say. This is really interesting.
Dad and I discussed it, and he said he wouldn't be scared to use it.
Old 05-17-2018, 02:48 PM
z31freakify
Just got the sample today ill try and send ot out today
Old 05-17-2018, 02:55 PM
truckeemtnfords
truckeemtnfords is offline
truckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud oftruckeemtnfords has much to be proud of
My money is on that it will come back good to go.
Old 05-17-2018, 02:57 PM
Bonanza35
Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Alright, will be waiting to here back. Being it was sealed I bet it's okay. It's up to what we had back then. I liked the old RPM 3000 oil that standard had. Didn't burn off and would stop oil burning in some cases.
Old 05-17-2018, 03:14 PM
hydro man 17
My dad always said that the only things that you can do to "hurt the oil" is to burn it or let it get dirty. But that was many moons ago before all of the additive we have today. That said I doubt much of anything is going to "drop out" from just sitting in a jug.
Old 05-17-2018, 04:07 PM
HKusp's Avatar
HKusp
HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Agreed. Let's see what Blackstone has to say.
Old 05-17-2018, 06:23 PM
z31freakify
Just to give specifics and the procedure I took when i emptied the 5gal bucket into two clean 2.5 gallon jugs. I used brake cleaner to clean any residue, and yes I waited till it dried completely. When filling the sample bottle I cleaned the funnel, again with brake cleaner and waited to dry and making sure no dirt or any particle fell in. Wifes sending the sample tomorrow.
Old 05-17-2018, 10:12 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.fordboy2 is gaining momentum as a positive member of FTE.
Interested to see the outcome.
  #28
Old 05-18-2018, 04:46 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Did the bucket have a CPI diesel oil spec on it, like CJ-4 etc?
  #29
Old 05-18-2018, 09:25 AM
z31freakify
I have No clue most of the lettering was gone due to some chemicals wiping most of the info out.
  #30
Old 05-18-2018, 09:43 AM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
If it was from 2010, it was CJ-4. I'd use it without issue. I can't imagine it would be a big deal.
Quick Reply: Would you run 18 year old oil?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
