1985 Inline 6 engine - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 05-10-2018, 09:51 AM
Tammy Prime
Tammy Prime is offline
Tammy Prime is starting off with a positive reputation.
Just bought a 1985 Bronco and found out yesterday that #1 cylinder is only showing 50 psi. Looking like $2100 or more to fix, wondering if we should look new engine to drop in (anyone selling one) or rebuild this one. It came from Arizona the guy we bought it from said it was running great...not so much.
Just looking for advice from Ford people
Old 05-10-2018, 12:28 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
AbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to all
Hi Tammy,
Welcome to the forums.
Since this is engine related (and not specifically Bronco related) you might also want to post your question in the dedicated 300 inline six cylinder forum.
https://www.ford-trucks.com/forums/forum52
My first question is what the $2100 is for.
Is that what a mechanic is charging to fix the cylinder? What does that all include? What is being fixed (ie. what is causing the compression loss)?
Need some more info on what's going on to give you a better analysis.
If it's just a leaking valve in the cylinder head (which can cause low compression), they're way overcharging. But if it's because of bad rings, etc. they're probably doing a partial rebuild anyway since they have to bore out the cylinders and put in new pistons/rings.
Otherwise, you might get quotes from local mechanics as to what they would charge to do a full rebuild since you can work directly with them. Or what kinds of prices they can get on rebuilt ones to swap in.
rangergirl94
10-01-2011 06:06 PM
65fordguy
04-29-2008 02:07 PM
ZANESAVIN
Engine Swaps
07-02-2007 10:31 PM
icepanl
12-02-2006 05:31 AM
LaceyG11
01-21-2002 11:15 PM
Quick Reply: 1985 Inline 6 engine
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
