1300 Miles And DEF Gauge Still At Full... - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 05-09-2018, 09:18 PM
MPawelek's Avatar
MPawelek
MPawelek is offline
MPawelek is starting off with a positive reputation.
Iíve read numerous old posts that the DEF gauge is not linear and generally drops 1/4 at a time. Should it be soon?
2 month old 2018 F-250. Thanks....
Old 05-09-2018, 09:39 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Maybe the dealer got it REALLY full? My DEF gauge is very good at showing a drain on the DEF when I'm towing.
Old 05-10-2018, 06:15 AM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
towing vs non towing effects the consumption rate.
Old 05-10-2018, 08:32 AM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Painted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant future
DEF is used to reduce the NOx of high combustion temps. If you are idling around a lot, Your combustion temps may not get very high and hence you may not use much DEF.
Don't worry about. 5000-6000-7000 miles you will need to add some. Your '18 model has the larger tank I think at over 7 gallons. So you will have to fill less often than the guys with the '11-16 trucks
Old 05-10-2018, 12:16 PM
nuctrooper
nuctrooper is online now
nuctrooper has a good reputation on FTE.nuctrooper has a good reputation on FTE.
Don't worry about it. Particularly if it was really full. It's really a non-event. Just check it/refill on the 5000 mile marks (5/10/15/20k, etc). Otherwise, forget about it and enjoy the drive.
Old 06-10-2018, 07:42 PM
mrgrayaz
mrgrayaz is offline
mrgrayaz is starting off with a positive reputation.
You must not tow much....I get 300-400 miles a gallon. I have to fill up the 7 gallon tank (2017) every 2-3000 miles.
To the OP: Its basically directly proportional to the fuel economy of the truck. Do a lot of highway cruising and getting 18mpg? your not going to use much DEF. Towing heavy and getting 7-9MPG? That's a whole different story. Either way - don't worry about it until the Truck tells you - it will give you plenty of warning.
Old 06-10-2018, 08:02 PM
MPawelek's Avatar
MPawelek
MPawelek is offline
Thanks for all the replies. I have now put 2600 miles on the F-250 with some towing and have used 1/4 of the DEF according to the gauge. All is good!
Majag86
25
05-15-2013 04:35 PM
RedBoat
01-23-2012 02:47 PM
screwy
2004 - 2008 F150
02-08-2007 08:09 AM
Tarmac
2004 - 2008 F150
11-06-2006 05:51 PM
bighoss550
10-05-2004 06:56 PM
Quick Reply: 1300 Miles And DEF Gauge Still At Full...
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
