Ground taillight question
Old May 9, 2018 | 12:29 PM
jrockdiddy's Avatar
jrockdiddy
if I have everything painted and taillight housing powder coated, how can I ground the bulb? Usually the housing grounds the bulb go the bed.
Old May 9, 2018 | 01:04 PM
abe's Avatar
abe
Run a separate wire from one of the housing bolts to a clean spot on the frame.
Old May 9, 2018 | 01:05 PM
oldmerc's Avatar
oldmerc
oldmerc
ground wire ?
Old May 9, 2018 | 02:05 PM
RiKi5156's Avatar
RiKi5156
After doing the same on my 52 F1 and having all sorts of ground issues I solved them all by sandwiching star washers between the bracket and body and then between taillight housing and bracket. Works great.
Old May 9, 2018 | 03:12 PM
jrockdiddy's Avatar
jrockdiddy
But my brackets are also powder coated
Old May 9, 2018 | 03:32 PM
RiKi5156's Avatar
RiKi5156
You’ll just have to try it to see if the washers will dig in enough for a ground.Mine are painted so it worked. Plus you’ll have to have a good ground between the bracket and body. I did mine that way so I wouldn’t have to run extra wires.
Old May 11, 2018 | 10:06 AM
CharlieLed's Avatar
CharlieLed
If you do not wish to disturb your powder coating then you will have to run another wire in addition to your hot wire. Attach the ground wire to the bulb socket inside the taillight housing...you should be able to solder it in place.
Old May 11, 2018 | 10:08 AM
jrockdiddy's Avatar
jrockdiddy
Thanks Charlie! That was the idea I was looking for.
NashvegasMatt
19
Sep 27, 2017 04:15 PM
66CustomCab
Aug 8, 2011 12:59 PM
willydad
Electrical Systems/Wiring
Feb 24, 2007 02:14 PM
Head Hermit
Jul 6, 2005 12:25 PM
