Bucking and clunks when shifting... ZF6 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 05-09-2018, 12:09 AM
beef tits
beef tits is online now
beef tits is gaining momentum as a positive member of FTE.
Alright so this has been going on for a while. When I am driving like a normal non-dingus, my truck bucks and clunks when I take it out of gear.. like something is binding in the drive-line. This happens usually when I am slowing down while in gear, and pressing the clutch in coming to a stop. When I am hot-******* it (full-on dingus), this doesn't happen. It's only when I am in like 1st/2nd gear in a parking lot.
I know this is a big dumb truck and big dumb trucks are just heavier and clunkier in general... but is this normal?
Also, I just pulled a truck camper and a trailer with another truck on it halfway across the country. CO to OH. 11 MPG at 60-65 MPH. 9 MPG at 70-75. Woof!! I sprung a minor fuel line leak somewhere along the line (small drips at every stop) and am hoping that was a big contributor. Was hoping for 13-14 at least with that load... about 9k lbs total.
Old 05-09-2018, 09:52 AM
NO_SPRK
NO_SPRK is offline
NO_SPRK is starting off with a positive reputation.
if the engine rpm changes when you take it out of gear i would check the ICP sensor. my zf6 truck can tend to hunt idle and run a little funny when coming off of a running rpm when pushing the clutch in.
Old 05-09-2018, 10:07 AM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
I haven't driven one of these in a manual but...of the trucks that I have driven with manuals many of them have some odd characteristics in the lower gears. Some of them would act like the clutch was still engaged even though the pedal was pushed to the floor and they would be hard to get out of gear if the RPM's didn't match for the speed of the truck and the gear it was in. Then if and when they did come out the trans would clunk back and forth from the pressure being released. The only solution to that was to hold slight pressure on the stick before hitting the clutch and sliding it out of gear simultaneously while depressing the pedal.
Old 05-09-2018, 11:18 AM
beef tits
Good call, My ICP sensor is newer but a generic ebay one, characteristics have not changed since swapping it out. It does seem to hunt for idle at times though, I should probably get a Motorcraft unit as well as a new pigtail.
Good to know. My clutch/flywheel/trans rebuild/driveshaft/rear end rebuild all have less than 10k miles on them so if this is how it is... I'll just have to get used to it. I've always owned smaller Toyota trucks and sportscars which were much smoother to shift and drive all around... I guess I'm not sure where to set the bar / what to expect with this Pig.
Old 05-09-2018, 07:23 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is offline
Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.
I guess my zf6 is a flawless unicorn. I don't have any of those troubles Walleye. Neither did my 88 chevy 5spd 1500, nor does my 71 F100 4 spd, or even the corvette. Maybe you rode in beaters with poor maintenance?
Old 05-09-2018, 07:29 PM
Walleye Hunter
Hmmmm....now that I think about it the trucks I'm thinking of were back in the '70's, one was a Dodge and the other a Chebby.
NO_SPRK
NO_SPRK is offline
I just changed my ICP sensor and the little bit of bucking right off of idle from going in reverse has gone away now I think it's mostly the chain driven transfer case and how smooth your shifting
Old 05-15-2018, 11:24 PM
00t444e's Avatar
00t444e
00t444e is online now
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
Mine does the Same thing you described, the key is to be easy on the clutch petal. The ZF6 is a bit of a clunky transmission in the lower gears. Also the chain in the transfer case has nothing to do with it, all the chain does is send power to the front axle in 4x4, in 2wd the chain isn't engaged it just spins freely.
snakedoc
1999 to 2016 Super Duty
05-20-2015 10:55 AM
stahl1911
Ranger & B-Series
07-29-2012 09:13 PM
EHC112
13
04-18-2009 04:56 PM
fsobolik
1997 - 2003 F150
10-07-2006 06:39 AM
ososa3
09-09-2002 05:12 PM
Quick Reply: Bucking and clunks when shifting... ZF6
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
