Is the cold a/c mod bad for the heater core?? - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 05-10-2018, 09:52 AM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
The Diesel Site valve never fully closed, but maybe that was the way it was designed. I wrote them and talked to them on the phone a few times regarding the valve and how I thought the very basic operation was failing. They claimed my vacuum pump was failing. Here I am 3 years later and the pump still works great.
I destroyed the DS valve and installed the Ranger valve last fall. This past weekend is the first time we had put the Ranger valve to the test and it did great.
Give what you have done a shot and if you are happy with it you are done. If you are not happy, install another ball valve in the other line and go from there.
Old 05-10-2018, 11:26 AM
HKusp's Avatar
HKusp
HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
If it was bad, they probably wouldn't have added it from the factory in '02.
Old 05-10-2018, 11:31 AM
HKusp's Avatar
HKusp
HKusp is offline
Originally Posted by Jaime74656 View Post
and why must everyone over complicate things? yes its vac opperated but no dead head here....this was a ranger/excursion valve BTW....just sayin'
That's pretty funny Jaime, if we look back at your post history, you have taken some pretty simple concepts and made some pretty complicated theoretical modifications of them.
Old 05-10-2018, 11:40 AM
brian42's Avatar
brian42
brian42 is offline
brian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud of
The vacuum operated valve is better than nothing but known to not block all the flow through the heater core. That's why Dieselsite sells a "better" version of it.
jstihl I wouldn't worry about it. I had two "Ranger" valves and both of them leaked on me. I recently replaced my injector cups and swapped to just a manual ball valve on the supply line to the cooler (at least I think it's the supply line). No issue with dead-headed pressure but no flow to improve cooling performance. I don't shut it all the time but when I do there's a noticeable difference in the cab when I do (colder).
It works for all settings instead of just Max A/C. That is good or bad depending on your preference. I prefer the dash/floor setting so now I have temperature improvement across the board but that's just me.
I've already given up on ESOF and went to manual hubs, why not one more thing? My next project is to use Sous' video to clean my evaporator.
Old 05-10-2018, 01:11 PM
jstihl
jstihl is offline
jstihl is starting off with a positive reputation.
Thanks for all the info guys. the ball valve seems to work great but more so in max a/c, as long as i am getting proper cooling to the engine it should work just fine...
Old 05-10-2018, 01:24 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Or to the 2000 PSD Excursion, when the Ex was first made.
Stewart
Old 05-10-2018, 02:43 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
Jaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to beholdJaime74656 is a splendid one to behold
hehe thats half the funz LOL but again you know how theories are supposed to be....broken
Old 05-10-2018, 02:56 PM
Randyholton
Randyholton is offline
Randyholton is starting off with a positive reputation.
Does anyone have the part numbers for each valve
Old 05-11-2018, 11:18 AM
av8or1
av8or1 is offline
av8or1 is starting off with a positive reputation.
jstihl- The previous owner installed this heft of crap on my 2000 F-350, FWIW:
It worked for him. I've never closed it off. Want to remove it, just haven't made the time yet to install a new hose...
Thanks,
Jerry
Old 05-11-2018, 01:41 PM
268Fords's Avatar
268Fords
268Fords is offline
268Fords is gaining momentum as a positive member of FTE.268Fords is gaining momentum as a positive member of FTE.
I installed a 1/2” sweat on ball valve a few years ago. In the summer time, I will open it once a week for a few minutes to flush it. I prefer manual options over vacuum valves. Just my opinion.
Old 05-11-2018, 05:06 PM
brian42's Avatar
brian42
brian42 is offline
I have the pictures on my laptop from when I did this recently. I'll take a look and see if I have the part numbers/sizes. I got the ball valve and barbs from Home Depot (or Lowes) and the hose clamps from the local auto parts store.
Old 05-11-2018, 05:29 PM
BLUEMAX65's Avatar
BLUEMAX65
BLUEMAX65 is offline
BLUEMAX65 is gaining momentum as a positive member of FTE.
I have the DS valve in my truck. I live in Phoenix so to say the least it's hot. It has made a big difference in my truck. Something I was told a long time ago from a old time HVAC guy was to turn off the a/c about one mile before your destination. Switch it to vent and it will dry out the condenser and get rid of the musty smell. One benefit to our trucks it would allow coolant to flow thru the heater core. I have done this for years on all my vehicles with no ill effects.
  #28
Old 05-11-2018, 05:57 PM
brian42's Avatar
brian42
brian42 is offline
I used a brass 1/2” gas ball valve with a 5/8” to 1/2” MIP connection on each end. I used thread tape to prevent leakage at the threaded connections.
  #29
Old 05-11-2018, 08:32 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
BBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant futureBBslider001 has a brilliant future
The heater core will implode and leave coolant EVERYWHERE in the cab. You're family will hate you and your wife will wonder why in the heck you got this god forsaken truck to begin with and why it takes a stupid mod to get the A/C to work properly. You'll wish you had bought a 6.7, but that comes with emissions crap. Don't mod the A/C....have a good weekend.
  #30
Old 05-11-2018, 08:45 PM
jhl3's Avatar
jhl3
jhl3 is offline
jhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to behold
Simply AWESOME!
Quick Reply: Is the cold a/c mod bad for the heater core??
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
