Vid of the 2019 Ranger testing - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > 2019 Ranger
Reload this Page >
2019 Ranger Everything about the new 2019 Ford Ranger.
Old 05-08-2018, 06:28 PM
Johnny Mayday's Avatar
Johnny Mayday
Johnny Mayday is offline
FTE Town Crier
Johnny Mayday has a good reputation on FTE.Johnny Mayday has a good reputation on FTE.
Until I saw this on the HP, I didn't know that Ford used robotic drivers to prevent human injuries, but I guess it should have occurred to me. That said, I really want to see what a Ranger Raptor could do...
Old 05-09-2018, 08:22 PM
Johnny Mayday
FTE Town Crier
https://www.youtube.com/watch?v=6RPkKcaRNdI
I wonder how long it'll be before someone swaps in the Coyote motor?
Old 05-31-2018, 03:36 PM
Pgh Rebel's Avatar
Pgh Rebel
Pgh Rebel is offline
Pgh Rebel has a good reputation on FTE.Pgh Rebel has a good reputation on FTE.
I'm willing to take the initial test drive!
Old 06-11-2018, 01:59 PM
92F350CC's Avatar
92F350CC
92F350CC is offline
92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future
Would a Coyote even fit in there? This truck was designed for I4 engines that they use overseas. And the Coyote is a huge **** externally.
Old 06-11-2018, 06:50 PM
YoGeorge
YoGeorge is offline
YoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud ofYoGeorge has much to be proud of
Every engine in the T6 Ranger and current Ford Everest is an inline 4 or 5 cylinder engine. So if you want to stay Ford-based, a V6 like the 2.7 or 3.5 Ecoboost is probably the biggest engine that will realistically fit... It would be nice to see one of those 2 engines in the new Ranger and Bronco.
Putting overhead cams on its V8's was not, imo, Ford's most logical engineering move. The Coyote is 29" wide compared to an old 460 at 27" wide...and the current Chrysler Hemi is under 27" with exhaust manifolds.
Here's an interesting article I found the other week about a V8 swap into a new Jeep Wrangler....but they are using a Chevy engine https://www.roadandtrack.com/car-cul...er-ls-v8-swap/
George
Old 06-13-2018, 11:45 AM
Pgh Rebel's Avatar
Pgh Rebel
Where there's a will there's a way. Or should I say where there's Jack Rousch Motorsports, there's a way! Leave it to Rousch to figure out how to wedge a V8 in that puppy! Too bad I suck at creating visual graphics because right now I'm envisioning a blacked-out 2wd Ranger wide body complete with a front chin spoiler, extra LED lighting, and a huge gaping mouth of a grille to feed cold air directly to a supercharger. Eat this, SVT Lightning!!
Old 06-26-2018, 02:26 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
If a guy can stuff a 5.0 in a 06-10 Sport Trac (done, check youtube) this new ranger should be easy enough.
Old 06-26-2018, 02:53 PM
YoGeorge
YoGeorge is offline
The SportTrac was based on the '02-'10 Explorer, which was specifically designed to hold the 4.6 V8. So it hardly takes "stuffing" to get the 5.0 into it--the Lincoln Aviator version even had the twincam 4.6 as standard. And the 3-valve 4.6 in the SportTrac (2006 and later) was quite a hot rod even in stock form.
The pre-2002 Explorer was the last Ford vehicle to use the 302 because the wider OHC V8's would not fit. The old pushrod 302 (and larger cubic inch variants of that engine) would make way more sense to swap into smaller engine compartments. If you have room for a new-gen 5.0, why not swap in a 500+ cubic inch version of the old 460?
Certainly anything can be done--you could fit a 5.0 into a Fiesta with enough money.
Old 06-26-2018, 03:01 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
We have a 08 4.6 Sport Trac and I looked over a new Ranger this spring as much as I could. Size is dang near the same if the Ranger isn't slightly bigger. I have to believe there is plenty of room for the 5.0 to fit with minor modifications.
Plenty of guys have swapped 2v 4.6's in 98-11 Rangers (same engine bay as my 97 302 Explorer which is tight) It's not impossible by any stretch but does take some work.
The idea of a brand new power train in a brand new truck would be the appeal, why go backwards in tech? if you can't buy it, build it the way you would if you could.
Old 06-26-2018, 03:13 PM
YoGeorge
YoGeorge is offline
We shall see how big the new Ranger/Bronco are under the hood. It's a world truck so it is being build with both left hand drive and right hand drive, and my suspicion is that an inline engine will end up fairly centered in the engine compartment so the steering column can run easily on either side of it. Even full size Ford trucks and vans have had engines and driveshafts shifted to the right side.
Like I said, anything can be done with enough money, but it's not like a modern aluminum version of the old 302 is low tech except for the pushrods, which don't seem to bother GM, Chrysler, NASCAR, or even Top Fuel dragsters...
edit--if "modern" is the objective, a 450 hp 3.5 Ecoboost out of a full size Raptor seems like the REALLY modern way to go.
JKBrad
2019 Ranger
07-18-2018 12:34 AM
IB Cristina
Newsletter Archive
07-18-2017 03:24 PM
Patrick R.
General Automotive Discussion
05-25-2017 11:46 PM
ProStreetDriver
07-02-2013 12:42 PM
Quick Reply: Vid of the 2019 Ranger testing
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
