65 or 66 F-250 Camper ?
Old 05-08-2018, 12:52 PM
Rick Bensco
Rick Bensco is offline
Rick Bensco is starting off with a positive reputation.
I just got a F-250 the guy I bought it from said it was a 66 but the title says 65. It also has a spot for two batteries and 3 gas tanks. Right now I'm just trying to figure out what I'm working with. I want to put in power steering so my wife can drive it. I noticed lots of info for converting a F-100 will the same stuff work with the F-250? I'm totally new to this type of fun.
Old 05-08-2018, 01:19 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
As I told you when I decoded your VIN and Warranty Plate (it's a 1966), the saddle tanks and dual batteries are not original to your truck, were added by a previous owner.
P/S not available in 1965 F100/250 2WD
Bendix P/S: 1966/68 F250 2WD; 1969 F100/250 2WD before serial number D96,001.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number D96,001; 1970/79 F100/250 2WD & F350.
You will also have to change the steering column, as the steering shaft is a different length: manual vs power.
Most people swap in the Ford/Saginaw unit. The Bendix unit is troublesome and the seal kits are obsolete, very hard to find and expensive if found.
THREE different P/S pumps. 1966 is 1966 only, 1967/77 uses the Ford/Thompson pump that has a steel reservoir. P/S pressure hose threads onto the pump.
1978/79's use the Ford C-II pump. Has a plastic reservoir, the P/S pressure hose connects to the pump w/a qwik connect fitting.
The C-II pump is a different shape than the Ford/Thompson pump, so uses specific mounting brackets.
There are no C-II pump mounting brackets with 360/390 engines, because both of these FE engines were cancelled after 1976.
Old 05-08-2018, 01:57 PM
Crop Duster's Avatar
Crop Duster
Crop Duster is offline
Crop Duster is gaining momentum as a positive member of FTE.
PS Pump
You can easily modify the Ford Thompson bracket to mount a CII pump. The bolt pattern and shaft are the same. I had to use a CII pump on my Cleveland for clearance on the headers.
Old 05-09-2018, 12:17 AM
Rick Bensco
Thanks
Thanks guys and NumberDummy for the V I N decoding I hadn't seen the old thread. I'm very new to this forum type of thing. I'm off to the junk yard when I have another day off work. I'll try to figure out how to post a photo of what we are working on. My 15 year old son has a year before he gets his license. The count down started Sunday afternoon when we drove her home.
Toyguy9
03-16-2006 06:26 AM
f-250-ltd429
40
02-27-2006 08:28 PM
anotherbrian
10-18-2004 03:52 PM
TheMailman
09-10-2002 10:17 PM
Quick Reply: 65 or 66 F-250 Camper ?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
